What compressor?
Old Sep 25, 2005 | 11:09 AM
turbo terry's Avatar
turbo terry
Default What compressor?
anyone know anything bout compressorss????
want one to use air tools, and perhaps have a go at spraying etc, dont know what litreage?? i would need?
any makes to stay clear of and any good ones??
cheers
Old Sep 25, 2005 | 11:12 AM
Red16's Avatar
Red16
i think you would be best off deciding which tools you want to be able to run, then that would dictate which compressor you would need, as it will need to be able to supply enough air for the chosen set of tools
Old Sep 25, 2005 | 12:34 PM
Brookesy's Avatar
Brookesy
I got an SIP 50ltr 2hp compressor and that seems to be pretty good and came with a spraygun but i mostly use it with impact tools
Old Sep 25, 2005 | 12:55 PM
THEYGOTMETOO's Avatar
THEYGOTMETOO
CUNT!
From: BLUE PILL or RED PILL ... All I offer is the truth, nothing more, nothing less. You choose.
Posted: Mon Jul 18, 2005 12:40 am Post subject:
Yup same compressor, basically compressors are rated by CFM (cubic feet per minute) or FAD (free air displacement) normally quoted at 90psi, FAD being the most informative but CFM will be a good indication of the compressors abilities. Get the highest CFM compressor you can afford.
Spraying is quite air intensive so you’ll need a compressor which is at least of a medium size (10CFM or greater with a receiver of at least 50 litres) or you’ll run out of air and have to wait for the receiver tank to build up pressure again - not the end of the world but extremely annoying.
Most commercial spraying equipment is HVLP (High Volume Low Pressure) which means whilst the pressure is quite low it will consume vast amounts of air, for home use I would avoid HVLP guns and go with a conventional spray gun. Personally I wouldn't buy a cheap spray gun as they tend to make learning 100 times more difficult, I would personally start of with something like a DeVil Biss Finishing Line or something similar.
Something else to consider; if you don't want to make a lot of noise oil-less direct drive compressors are not a good idea, they have loose internal tolerances (because they are oil-less) so make an awful noise. Get a slow running belt driven oil filled one if possible.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
YODI
Aug 30, 2015 01:12 PM
IAN RS2k
Aug 18, 2015 07:51 PM
