Wire hanging off?
Wire hanging off?
Cosworth YB just above the starter motor going into the block?
Sensor for oil pressure?
May explain why my rocker gasket went pop?
I might of knocked it as I was changing my gasket then, im just trying to find the fault?
New switch then added to the list, easy fix or a new one and how easy is fitting one of those babies?
The gasket is not a pressure seal. It only prevents leakage from oil splashing from the cams.
Excess crank case pressure through worn rings/bores, or blocked, poor or insufficient breathers will cause the gasket to blow out.
Mark RS
12-10-2015 06:01 AM
