Esc Cos REAR brake sheild ??? how to remove?
on the back brake set up, the esc cos has a metal circular sheild.. how is this removed as some rascal painted it in the same blue as my bells USED to be ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
cheers
cheers
If it the same as a 3dr mate.I think you have to strip the hub away from the backplate and then it comes off.Undo the 4 bolts that hold hub to backplate and it will be loose.You will also need to remove Big fook off nut on hub that holds bearings in etc HTH
track.focus'd
12-08-2015 05:53 PM
