Nice one Zoo Motorsport
I picked my Fiesta up from Zoo Motorsport this afternoon following a week of work. Karl fitted an adjustable rear beam to the car and carried out a full geometry set up (front lower arms are adjustable Fiesta Frenzy ones) which has totally transformed the handling. Combines with my stage 2 CTS 'box with a Quaife ATB torque steer has almost been aliminated and high speed stability is superb.
Karl also replaced all the brake pipes with braided hoses and fitted a new fuel filter again with braided hoses and connectors and also made me a nice heat sheild to protect my brake servo. As well as all this he replaced my rear crank seal and sump gasket which were leaking and I have to say Karls attention to detail gets my thumbs up.
Tomorrow I am taking the car to another Karl (Karl Norris thats is -another top bloke who's attention to detail is everything you need from a tuner) to check over its fueling following the fitting of a new ECU and fuel regulator (L6 management) and the car is finished. Well until I think of something else that is.
Pictures of the car and engine bay (check out Zoo's workmanship) are attached.
![](https://img.photobucket.com/albums/1003/AndyKam/CIMG3315.jpg)
![](https://img.photobucket.com/albums/1003/AndyKam/CIMG3312.jpg)
![](https://img.photobucket.com/albums/1003/AndyKam/CIMG3313.jpg)
![](https://img.photobucket.com/albums/1003/AndyKam/CIMG3318.jpg)
![](https://img.photobucket.com/albums/1003/AndyKam/CIMG3314.jpg)
![](https://img.photobucket.com/albums/1003/AndyKam/CIMG3319.jpg)
![](https://img.photobucket.com/albums/1003/AndyKam/Dscf29351.jpg)
![](https://img.photobucket.com/albums/1003/AndyKam/DSCF00641.jpg)
Only bit I personally dont like is the brake hose going through the inner wing like that. Not any form of diss at Broms work as it looks spot on - but there are proper fittings available for this.
Im sure with 2 lots of "Karl" working on your car it will be totally transformed
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Top stuff as ever
yes tony there are fittings if you want to fit it at 90 degress as i did not
the fitting on the inside of the inner wing( that goes to the brake caliper) was directly below where it came threw the inner wing
its p cliped and has a large rubber crommet in the inner wing
and its a oval hole so there are no kinks in the hose
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
