dump valve removal question
i want to take the forge dump valve off my saff cossie, do i need to refit the standard ford plastic one on the other side as it has been removed and bunged up. also how do i get the loudest wastegate noise?
Just take the dump valve off, block the vacuum line on top of the dump valve and that should give you the turbo chatter if you run enough boost. The standard airbox will stop the noise if there is not enough boost.
cossie09
11-10-2015 06:29 PM
rsstav
Ford Focus RS Parts for Sale.
16-08-2015 08:38 AM
rsstav
11-08-2015 04:22 AM
