Testing alternator on Range rover. UPDATE
Old Sep 4, 2005 | 04:05 PM
TIFF's Avatar
TIFF
Chasing Radders
Default Testing alternator on Range rover. UPDATE
Any body know how to test if the alternator is charging the battery on the chelsea tractor.
Something is draining the battery and I'm want to eliminate the alternator before I go about buying a new battery.
I have a multi meter just need to know where to put the probes.
Tiff
Old Sep 4, 2005 | 04:06 PM
xr4x4rs's Avatar
xr4x4rs
on the battery mate
set the meter to 20v dc
red on pos black on neg while its running
Old Sep 4, 2005 | 04:08 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
As XR4x4rs says, put the multimeter leads on the battery terminals, select to voltage (of a suitable range) make sure its DC volts!
With the engine off it should read ~12v, start it up, if the alternator is working well then it will read about 13.2-14.5ishv
Old Sep 4, 2005 | 04:42 PM
TIFF's Avatar
TIFF
Chasing Radders
Ok.
20 dcv the battery reads 13.5 or there abouts when engine off.
turn engine on and it goes to 13.88
What does that mean?
Tiff
Old Sep 4, 2005 | 04:44 PM
philc's Avatar
philc
its ok in an ideal world i would get it load tested and your battery drop tested as well, should of be a few quid at a auto sparky place, is lucas still in warwick, they can sort it no problem.
Old Sep 4, 2005 | 04:45 PM
TIFF's Avatar
TIFF
Chasing Radders
Phill
are you saying that sounds ok?
Tiff
Old Sep 4, 2005 | 05:03 PM
TIFF's Avatar
TIFF
Chasing Radders
Old Sep 4, 2005 | 05:14 PM
xr4x4rs's Avatar
xr4x4rs
yes that sounds about right most car alternators are between 13.5 to 14v
any higher and your alternator is overcharging
why do you think wrong with it
Old Sep 4, 2005 | 05:32 PM
TIFF's Avatar
TIFF
Chasing Radders
went to the car the other morning and it wouldn't start but did off a jump.
Used it yesterday went for a run left it a few hours and it started ok.
Left it over night and the battery is flat.
Old Sep 4, 2005 | 05:38 PM
NUTS RuS's Avatar
NUTS RuS
New battery time
(unless the kids have left the DVD screens on etc )
Old Sep 4, 2005 | 05:39 PM
xr4x4rs's Avatar
xr4x4rs
as nuts rus says new battery mate
its not holding its charge
or theres a drain sumwhere
Old Sep 4, 2005 | 05:43 PM
TIFF's Avatar
TIFF
Chasing Radders
Originally Posted by NUTS RuS
New battery time
New battery it is then i think
Old Sep 4, 2005 | 05:45 PM
philc's Avatar
philc
just switch your meter to amps and put in series with the positive cable, leave the ignition off and see what the current draw is, should be very low if its over an amp or so you have a drain, if so pull the fuses one at a time and see if it the current draw drops, you then now what circuit the drain is on
Old Sep 4, 2005 | 06:10 PM
TIFF's Avatar
TIFF
Chasing Radders
In series???? Sorry not very technical when it comes to these things...
Old Sep 4, 2005 | 06:16 PM
TIFF's Avatar
TIFF
Chasing Radders
I take it thats DCA on my multi meter?
What number? I have 2000, 20m 200m 10A
Tiff
Old Sep 4, 2005 | 06:19 PM
Jim Galbally's Avatar
Jim Galbally
tiff, that tests means your alternator works but battery is draining... if the alternator was knackered, it'd jump, then konk out
Old Sep 4, 2005 | 07:00 PM
philc's Avatar
philc
tiff, in series means inline, just disconnect your positive lead, switch the meter to 10amp scale and place one probe on the battery positive terminal and the other on the end of the lead. Shall i pop across
Old Sep 4, 2005 | 07:19 PM
Eagle's Avatar
Eagle
Super Moderator
its like installing a flow meter in line on a water pipe .. ..
take the red connector off of the battery ...
put the red probe onto the battery and the black probe onto the battery terminal you have taken off .. all with the ignition switched off .. then see what it reads ...
Old Sep 4, 2005 | 07:29 PM
DazC's Avatar
DazC
Batterys fucked. Probably has a dead cell.
tankybaby66
Feb 6, 2016 02:24 PM
rsguy
44
Sep 29, 2015 03:29 PM
