Still old school but this time a Fiesta!
Bit of spec for you taken from the geezers advert so don't blame me for the grammar and puntuation
MK1 FIESTA RWD COSWORTH
ENGINE--PINTO 2000cc BLOCK COSWORTH HEAD 45 WEBERS
PIPER CROSS FILTER VERNIER PULLYESx2 ELECTRONIC IGNITION
COIL BOOSTER PACK 16 ROW OIL COOLER 2xELECTRIC FUEL PUMPS
LIGHTENED AND BALANCED CRANK AND FLYWHEEL
PIPER HEAVY DUTY PADDEL CLUTCH PACET 14inch FAN
ALLOY CATCH TANK BREATHER SYSTEM TONY LAW MANIFOLD
GEARBOX---QUAIFFE 4SPD STRAIGHT CUT BOX RS2000 CASING ROSE JOINTED QUICK SHIFT STICK ONE PIECE PROP HEAVY DUTY GREASABLE JOINTS
AXEL----4.6 QUAIFFE LSD 5 LINKED ROSE JOINTED BUSHED HALF +HALF
FRONT AND REAR WINDOWS GLASS REAR QUARTER WINDOWS POLY CARBONATE DOOR WINDOWS POLY CARBONATE WITH SLIDERS
FRONT SUSPENSION BILSTIEN COIL OVER STRUTS WITH ROLLER TOP MOUNTS WCXM + MOUNTS QUICK RACK FITTED
REAR SUSPENSION BILSTIEN COIL OVERS
BRAKES---BIAS PEDAL BOX WITH DASH ADJUSTER HYDRAULIC HANDBRAKE+MECHANICAL HANDBRAKE WILL WOOD SUPERLITE 4 POT CALIPERS ON FRONT SIERRA COSWORTH ON THE BACK 266mm CROSS DRILLED DISCS ON REAR ALL BRAKE LINES FUEL LINES INSIDE
SHELL--- FULLY SEAM WELDED FOAM FILLED ALLOY WIDE REAR ARCHES FIBER GLASS FRONT ARCHES FIBER GLASS BONNET FULL ROLL CAGE DOOR BARS DIAGONAL CAGED TO ALL STRUT TOPS
FIA APPROVED BUCKET SEATS 4 POINT LUKE HARNESSES MECHANICAL PLUMBED IN FIRE EATER 6.6 GALLON FOAM FILLED PETROL TANK ALLOY FOOT REST HELMET NET
8INCH ALLEY CATS WITH NEW SOFT TARMAC YOKOHAMAS
this is NOT A LIE spadge,
i saw that yesterday on ebay and thought ''watch spadge buy that'' Honestly i dont lie!
You big girl...
When ya breaking it?
You big girl...
Whatever floats your boat I suppose - you're gonna look like Bowser out of Mario Kart driving that thing
Lee i don't doubt it mate
I have been watching it all week and was pleased it didn't show up on most cossie related searches!
Westy this is a properly sorted car and not a Max Poo mobile like your more familier with
Originally Posted by Sean Bicknell
Cool Man!!!!!! I can't wait to see you out on track in it matey!!
As long as i can keep it away from lamp posts in the mean time
Going to make a few changes to it externaly starting with those fookin huge mud flaps
