Heads off good or bad and whats the spec found more now ?
Old 18-08-2005, 10:20 PM
DOO
DOO's Avatar
Default Heads off good or bad and whats the spec found more now ?
1st a big thanks to (MADade) ADE for have the car at his garage and showing me what to do and doing most of the work takeing the head off and (ark1) big bob for his lifting
After the cambelt tensor came off at 120mph last night
Had nightmare takeing the head off i found i had a long stud cov did not know that before also had to that the turbo and manflod off as will to lift it out:
Don`t look to bad just a few marks on the tops of the pistons bores are fine all vaules are bent not sure on the guides yet?
Are the pistons standerd ??
also found a pair of bd10 cams
Why a long stud cov anygood can they be used again ??
Could of been a lot worse
Heres a pic of Ade`s behind mine also broken waiting on a berine diff
530+bhp / 185.5MPH MAD saff (in the wet)
Old 18-08-2005, 10:27 PM
pee vee
pee vee's Avatar
wicked news that it aint too bad mate
hope shes all back together soon
least it dont look like its damaged the head !!
will the pistons be ok
Old 18-08-2005, 10:31 PM
DOO
DOO's Avatar
They look fine just a few marks to the tops that will clean up
Old 18-08-2005, 10:39 PM
ark1
ark1's Avatar
Any t ime you need help mate
Old 18-08-2005, 10:40 PM
richm
richm's Avatar
pistons don't look standard from the pics.. low comp to some degree IMO. are there valve cutouts machined in, or are thay all dents??
Old 18-08-2005, 10:44 PM
Karl
Norris Motorsport
Karl's Avatar
Pistons are not std, they have had the bowls machined and it appears the perimeter of the crown may also have had the very top machined down. As for what C.R that gives you I can not say without buretting the piston crown and measuring the piston protrusion at TDC.
Check the pistons have not cracked where the valves have hit and if not then carefully dress the tops of the pistons to remove any sharp edges/burrs.
With the head inspect the valve guides but I would assume several will be cracked due to the valve stems being bent. When you replace the guides also ensure you cut the seats correctly before trying to lap in your new valves.
Block appears to have conventional 6 long studs. Don't go trying to use a Steel headgasket unless you intend to machine the deck face of the block, otherwise keep with the std type such as the 611 or the 1261 you had on there allready.
Old 18-08-2005, 10:45 PM
the strut brace
the strut brace's Avatar
those pistons look fooked to me mate, they look like they have valve cut outs but i fear they are dints from the valves hope its ok though mate
CraigN
CraigN's Avatar
hmmmmm
your pistons look like they have come into contact with valves mroe than the once dude
if there not cutouts !
also why would you long stud and engine and fit a grp a headgasket ????
do you know the spec of the engine ?
looks like more than a stage 3 build to me speak to the builders of the engine
ignore what i said as karl jsut answered it
DOO
DOO's Avatar
Thanks for you advice Karl
It looks like dents on the pistons but not sure TBH
The engine was built by bluesprint about 7000 miles ago that the owner before me had it all done.Did not have any paper work for the job. as it was a favor for favor type deal.
So i am clueless about the spec..
Was told it had low comp but had nothing to prove it and i did not know about the long stud whats that all about?
Old 18-08-2005, 11:12 PM
MAD Ade
MAD Ade's Avatar
Haven't cleaned them properly yet, will do so tomorrow and inspect them very closely. The photos make the valve contact look worse than it is because the valves have taken the carbon off where they hit.
Ade.
Old 18-08-2005, 11:45 PM
heeman10
heeman10's Avatar
Carbon or no carbon, there's no denying there's been valve-to-piston contact there, same for the other three pistons from the looks of things. Would it be wise to use them again? (Actual question, not bitchy rhetorical statement!)
Old 19-08-2005, 06:16 AM
foreigneRS
Testing the future
foreigneRS's Avatar
no problem to use them again, as long as any sharp edges are taken off to prevent stress raisers and hot spots.
Old 19-08-2005, 06:56 AM
St3V3_C
St3V3_C's Avatar
Glad it doesn't look too bad mate.
Old 19-08-2005, 09:02 AM
Alvyn
Alvyn's Avatar
I'm yet to see a Cossie that hasn't had some sort of valve 2 pistons contact that looks to be light contact IMO compared to some I've seen
Old 19-08-2005, 09:15 AM
richm
richm's Avatar
mine has no contact marks at all
but agree it is uncommon!!
Old 19-08-2005, 09:21 AM
GARETH T
GARETH T's Avatar
thats because you older ( ) men know how to do nice gearchanges, where us younger ( )men miss the gears and overrev the engine
Old 19-08-2005, 11:51 AM
DOO
DOO's Avatar
Cheers lads for you helpfull comments
TBH i happy now i found i got low comp pistons and long stud cov i did not know i had
Old 19-08-2005, 03:37 PM
DOO
DOO's Avatar
Anyone got any idea what sort of power the above could handle roughley??
Old 19-08-2005, 07:31 PM
Damo V
Damo V's Avatar
you need to know what the CR is mate EXACTLY as Karl said before you talk about mapping / bigger power, plus you will have to junk baby turbo
My advise would be to get somwone like Karl o rebuild your head and run you through measuring the volume of the bore, then they can work out exactly what CR is once head has been/ is being built
Old 19-08-2005, 07:36 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
Il put money its 7.5:1 bearing in mind the pistons have deffo been dished and was done by bluesprint
Old 19-08-2005, 07:38 PM
Damo V
Damo V's Avatar
that will quite possibly change a little once the head been repaired /worked
Old 19-08-2005, 08:08 PM
DOO
DOO's Avatar
I will get the CR checked some how
It`s getting even better now and i thought i had a standerd rebuilt engine
Low comp
long stud
ported head ?
god knows what cams or crank rods i got etc..
just took the inlet off and found this done to the head don`t look standerd to me??
Old 19-08-2005, 08:25 PM
Rene
Rene's Avatar
glad the damage aint to bad mate
Old 19-08-2005, 09:52 PM
DOO
DOO's Avatar
Cheers matey
Old 20-08-2005, 08:59 AM
DOO
DOO's Avatar
looks like it could do with a polish to me or is ment to be rough in the ports in the head??
Old 20-08-2005, 09:01 AM
Graceland
Team HOTHOT!
Graceland's Avatar
looks like someone has been busy and opened up the inlet tracts on the head too Doo
Old 20-08-2005, 09:11 AM
Phil
Jeebus
Phil's Avatar
DOO, I don't think they are supposed to be polished. I'm pretty sure Stu said he doesn't polish them when he does them (may be wrong on that!)
Old 20-08-2005, 09:15 AM
The DIVA
The DIVA's Avatar
Inlet ports are meant to be slightly rough mate,if they are polished water droplets form on the polished surface and break up the air flow...
Old 20-08-2005, 10:06 AM
Graceland
Team HOTHOT!
Graceland's Avatar
surely you mean fuel droplets as water doesn't burn very well
Old 20-08-2005, 10:29 AM
Alvyn
Alvyn's Avatar
when using water injection maybe
Old 20-08-2005, 10:31 AM
Graceland
Team HOTHOT!
Graceland's Avatar
can't honestly see water atomising and gathering on polished surfaces tho like fuel does
Old 20-08-2005, 10:35 AM
Rhys
Rhys's Avatar
Gutted!
lol my piston wasnt half as bad as those when valve seat went and wa sonly one piston. I rebuilt it though as i couldnt put it back together knowing pistons was like that Whack some new ones in there DOO at last u know its 100% then mate.
Old 20-08-2005, 12:33 PM
xr4x4rs
xr4x4rs's Avatar
head wise mate
put gasket on the inlet and exhaust and take a pic so we can see the port sizes
inlet side shouldnt be polished but exhaust side should
but by the looks of things not that much damaged in the engine bay
Old 20-08-2005, 03:55 PM
DOO
DOO's Avatar
Took out the vaules all bent but the valve guides are fine
How the you measure how much thickness is left on The head before i get it skimed??
Pistons should clean up ok not sure if the exasust ports have been ported should be able to tell once cleaned up
Old 20-08-2005, 04:11 PM
digita1dragon
digita1dragon's Avatar
Think you want to measure the width of the combustion chambers Tone and work it out from there
Old 20-08-2005, 04:13 PM
xr4x4rs
xr4x4rs's Avatar
there should be a brass indicator in one of the corners of the head
this is your indication mark on how far the head can be skimmed
but if its flush then its usually on maximum skimness alll ready
Old 20-08-2005, 04:18 PM
DOO
DOO's Avatar
Ok mate i can now see the brass thing on the left top corner but me mates got the head i get him to check ot tomorrow
Old 20-08-2005, 04:50 PM
xr4x4rs
xr4x4rs's Avatar
thats the one mate top left of the pic
Old 20-08-2005, 07:10 PM
DOO
DOO's Avatar
Cheers mate
Got a few bent vavles all 16
Guides are ok though
Old 20-08-2005, 07:30 PM
silky16v
Get on That!
silky16v's Avatar
would advise u change the guides too chances are u won't be able to see any cracks that may have appeared in them.
you don't want a piece of valve guide dropping into your engine
Quick Reply: Heads off good or bad and whats the spec found more now ?
