********S2 RST suspension question************
Fucking superstar........
Alrighty!
I need to know about turreting the rear suspension on a RS Turbo. The pishy trailing arms on the rear don't cut it. I knwo this has been done before, and it was one of my fellow jocks that had it done (no names incase it a, ssshhhhhhhh, secret)
What lower setup would you use? What car would you butcher for the top assembly? How much would it cost? Hmmmmm. I wanna run coilovers all round, and basically have summit better cos the back it well twitchy under braking!
Any help is good help!
buy some prefabbed turrents.
Fit coilovers, use existing wishbone.
or if you want to do it properly fabricate new tie bars for everything.
Rose joint everything.
and make everything adjustable.
most rally fabrication places will have these, you might be lucky and able to obtain mk3\mk4 from gartrac themselves, otherwise i would say get some bog standard turrets i.e mk2 escort ones and customise them to fit
thats when you have to start knowing exactly what your doing.
the fabricating bit is the easiest bit, but choosing the rite poundage, and setting the toe in/out, camber etc etc is a complicated job
07-10-2015 12:56 PM
SMILER258
28-09-2015 09:04 AM
