Brakes problem
Old Aug 18, 2005 | 08:55 PM
haz87's Avatar
haz87
Default Brakes problem
Right just put rs turbo breaks on all round(disks up front, rear drums). First of all will a 1.3 master cylinder be sufficient to power them?
And secondly they are biting but at a very low pedal point? Is this simply air in the system or a fooked servo, or is it the 1.3 master cylinder not being powerful enough?
Old Aug 18, 2005 | 09:04 PM
Al Bags's Avatar
Al Bags
Hiya ... The 1.3 Master Cyl is slightly smaller diameter on the bore. That will increase the travel requirement slightly for that caliper. Servo will be fine. If you are ABSOLUTELY sure you bled all the air out the system, and the rear shoes are working correctly, plus any new pads are fitted/contacting ok, it could be damage to the master cyl seals caused by the travel into a different area in the cylinder (like when the pedal goes to the floor) This happens on older M Cyls. Change it if you have to.
Have a rebleed first, tho. Bed the brakes in lightly nearby first!
Old Aug 18, 2005 | 09:09 PM
haz87's Avatar
haz87
generally speaking if its bled correctly, then the pedal should feel firm reasonably high up like any normal brakes tho even tho its on the 1.3 yer?
Old Aug 18, 2005 | 09:37 PM
haz87's Avatar
haz87
bttt
Old Aug 18, 2005 | 09:42 PM
Al Bags's Avatar
Al Bags
What I said, I think
yatta
May 21, 2016 10:31 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
focus2351
Sep 9, 2015 09:33 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
