Clifford Concept 600 sensor adjust help!!
Old Jun 28, 2004 | 03:17 PM
Lee1972's Avatar
Lee1972
Formerly COSSIE_LEE
Default Clifford Concept 600 sensor adjust help!!
I got the concept 600, one with the external sensors that bleep when you get near the motor, only thing is you dont have to be that near for it to bleep
i called GAP Security, who fitted it and they told me they dont wanna know coz its over 14 months old
its driving me potty, just got a new job and it keeps bleeping in our car park!!
Does anyone know how to adjust the sensors? I did it once but cant remember how to do it, all i can remember is its a button combination on the master control then you can adjust the sensors up or down....
hopefully someone will know
cheers!!
Old Jun 28, 2004 | 03:26 PM
D19 STE's Avatar
D19 STE
That must be a pain in the arse for you mate hopefully you get it sorted
Old Jun 28, 2004 | 03:48 PM
zvhturbo's Avatar
zvhturbo
Clifford web site has all the user manulas in PDF file for download mate.
Download it and have a read through.
http://www.clifford.com/guides/ogs/c...600_owners.pdf
Matt.
Old Jun 28, 2004 | 03:59 PM
zvhturbo's Avatar
zvhturbo
COSSIE LEE,
Would you reccomend Clifford alarms??
Have you had any problems with it?
I'm getting one soon and i've been told you get lots of problems with them
Thanks
Matt.
Old Jun 28, 2004 | 04:18 PM
gingeRS's Avatar
gingeRS
dunno how to adjust them up or down but if you press the two diagonal buttons (top left, bottom right) on the remote when armed, it should flash 4 times and this disarms the external proximity sensor
hope this helps
cliffords rock, very highly recomended, only if installed by a pro though
Old Jun 28, 2004 | 05:09 PM
lamar69er's Avatar
lamar69er
hope this helps
Cheers GingeRS, just pressed them two buttons and got me proximity sensor working again, its been bugging me for ages, thought it was knackered!
Old Jun 28, 2004 | 05:11 PM
ARMOURER's Avatar
ARMOURER
Be careful coz if u get it wrong it causes a whole heap of shit to go wrong with the alarm system
Old Jun 28, 2004 | 05:19 PM
TONY C's Avatar
TONY C
just take it to another clifford dealer, i'll also ask how my bro does it, by the way, it don't seem to be able to be done by the clifford wiz-net
Old Jun 28, 2004 | 05:24 PM
lamar69er's Avatar
lamar69er
yeah to adjust them then....
1. get the master remote the one with the side button on!
2. turn the alarm off i.e. press the big button
3. press the side button 3 times
4. then press the bottom button on the alarm fob, it should chirp at u!
4. now press the left and right buttons to adjust the inside sensor, its should make a sound going higher and lower in a chirp
5. when ur done press the bottom button again this will alow u to adjust the outside sensor, again high and low chirps
6. when ur done press the bottom button again, and it should chirp 2 times
7. then pess the big button to exit the mode thingy
8. and press the big button to activate the alarm to try out the settings!
its a bit of a pain, I suggest u keep the inside settings around the same, as this is very sensitive, the outside can be adjusted accordingly, I have mine fairly sensitive as I can adjust it pretty easy, also if u press the side button twice and the big button it puts the alarm into silent. I would be carefull thou as u could knacker it all up and make it too sensitive, try little adjustments!
Old Jun 29, 2004 | 06:36 AM
Lee1972's Avatar
Lee1972
Formerly COSSIE_LEE
first off, cheers zvhturbo for the manual link
Personally i think thaty clifford alarms are good, ive had 2 alarms in 2 cars, had the concept 600 for 2 years and the only problem i had was when it was first put in it got wet but it got replaced and its fine with a plastic bag over it!!
lamar69er, tried following wot you said and it didnt work so i read the manual and it said press the button on the left instead of the bottom button and that adjusted the internal sensor.
Didnt say how to adjust the external sensor though....
any ideas anyone?
my alarms been in for 2 years so maybe its a older version than yours lamar69er, anyway, thanks for the help!
Old Jun 30, 2004 | 07:55 PM
Lee1972's Avatar
Lee1972
Formerly COSSIE_LEE
anyone got any ideas?
Old Jun 30, 2004 | 09:26 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Another slant on this one.......
Where is the actual External Prox sensor positioned?? (I bet it's near the handbrake)
Old Jul 1, 2004 | 07:04 AM
Lee1972's Avatar
Lee1972
Formerly COSSIE_LEE
yeah it is but the position aint the problem, when i had the alarm installed i though it would be a good idea to adjust the sensor so it was more sensitive so i called gap and they told me how to do it..........
that was alright until i got a new job and have me car parked in a constantly used car park.
i just need to adjust it so its less sensative, the pdf tells you how to do the internal sensor but not the external
Old Jul 1, 2004 | 07:19 AM
smokey's Avatar
smokey
Default Re: Clifford Concept 600 sensor adjust help!!
You're not parking under a tree are you? This sets the beeps off as the tree castes a shadow over the car and is perceived by the sensor as movement near your car.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
Fezman1
Oct 2, 2015 01:22 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
