Extra Radiator
Old Aug 17, 2005 | 04:25 PM
Rick's Avatar
Rick
Default Extra Radiator
I want to put in an extra small motorbike rad in my s2 to help on hot days in traffic etc. Question is, how do i plumb it? Do i put it in series with the std rad? Problem i can see, is that bike rads have small bore's, which may restrict the flow? Or, do i tee into the cooling circuit, and put it in parallel? It might not get coolant flow then :S
Old Aug 17, 2005 | 04:58 PM
wayneclayden's Avatar
wayneclayden
590 BHP/Ton
just plumb it into the turbo water outlet
Old Aug 17, 2005 | 11:02 PM
Rick's Avatar
Rick
Does this work? Out of the outlet, into the second rad, then out and into the original rad turbo outlet?
Old Aug 17, 2005 | 11:03 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Can't see why not. Pre-cooling the Super-heated water that comes out of the Turbo must have an effect.
Old Aug 17, 2005 | 11:06 PM
EIL132's Avatar
EIL132
As above, would just be a pre rad as in Cossie apps
Old Aug 17, 2005 | 11:13 PM
Rick's Avatar
Rick
Old Aug 17, 2005 | 11:14 PM
Al Bags's Avatar
Al Bags
Y - That will work OK .. just make sure the pipework is a good job!
I've also fitted them in the heater loop before (downstream of the heater)
That is also where aeration is definitely not an issue.
Old Aug 17, 2005 | 11:25 PM
Rob84's Avatar
Rob84
cooling the water/steam, using the turbo cooler from Pro alloy, that comes off the turbo b4 it goes back into the rad makes the WORLD of difference top mod
Old Aug 18, 2005 | 07:38 AM
Tim's Avatar
Tim
Just use a pro alloy rad the diff is tremendous and lots easyier and cheaper in the long run my temps are mint much better than the ford rads.
Tim
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
