anyone know about airbags???
the airbag warning light keeps flashing!!! flashes 4 times then pauses then 4 times again!!!!!
ford want £70 just to look at it!!! and say they are the only ones who can do it..... robbing barstuards!!
anyone know what it means???? is the airbag gonna pop at any moment???
any advice would be great!!!!
thanks!!
thanks!!
I know if you set one off under a cone with a heavy base it will go fucking high, and you will be scared of it coming down on your head but wont wanna look up incase it hits ya in the face, so you just sorta run around and hope for the best
LOL
well thanks for that!!! sounds like a good laugh!!
when we were kids we used to buy them little screamer rockets on bonfire night, we would break the sticks off and bout 20 of us would all stand in a group light em, throw em in the air and run!!!! no that is fun!!!
Re: anyone know about airbags???
thanks!!
thanks!!
leave ignition off for 15 mins then unplug both sides under seat and plug them back in again. start car and switch off, restart and it should have cleared light.
hth
Tricky
hi mate i work for ford and yes they are robbing bastards! it will be the seat belt pretentioner multi plugs under the plastic trims by the seats (trim near to the inner seal) pull the trims up both sides and you should see a yellow multi plug, if you stick a cable tie round the multi plugs this should fix your problem. i would advise if you are going to disconnect the multi plugs, have the battery disconnected for about 10 mins first hope this helps
cheers dan, looks like all you bods have solved my problem, really didnt want to give my hard earned to ford and hopefully i wont have to now!!!!
i spoke to an engineer on my way out of fords and asked him and he didnt help either!!! such a simple problem and they want to charge £70!!!!!!
CRIMINAL
CRIMINAL
