quick spraypainting question
ok just bought the paint and thinners for the spraying of my front bumper, got me a new gravity feed gun etc, but need to check on a couple of things first,
The first thing is how much thinner do i need? i am going to be using 0.5 ltrs of diamond white
the second thing is prep, when i have sprayed the bumper got a finish i am happy with, do i then mop it/cut it with cutting compond? is this correct and also is there anything elsei should know please?
thanks for any help
thanks for any help
if you are usin cellulose paint then you need to mix the paint 50/50 with the thiners , give it a few coats of paint or it will be too thin , dependin upon your finished result it may need yet may not need copound to get the finish perfect,.
on my cut out 90 spec bumper, it had some chopping about, always look at the primered finish for imprefections in the filler/bumper,
i must of primered mine several times after imperfections showed up in the filler.
SMILER258
28-09-2015 09:04 AM
