Cossie rad dimensions req
Old 13-08-2005 | 08:04 PM
900ss's Avatar
900ss
RWD Racer
Default Cossie rad dimensions req
As above needed for my current project below
Has anyone got the dimensions of a 2wd/4x4 Cossie rad to hand?
Or
Put it another way, can someone go measure the spare 2wd rad you may have lol.
Btw, Side mount brts will prob be cut off, so don’t inc them
Needs to fit this
Old 13-08-2005 | 08:06 PM
SPADGE's Avatar
SPADGE
My Pro-alloy one was 320mm heigh by 740 wide without the brackets if that helps
Old 13-08-2005 | 08:17 PM
900ss's Avatar
900ss
RWD Racer
Just measured the gap up.
That should fit fine Spadge
I shall go in search
gcfcos
59
06-10-2015 06:04 PM
XR4
Ford XR Range
01-10-2015 01:46 PM
A.t.p
29-09-2015 06:04 PM
cossie330
27-09-2015 05:13 PM
Russ Payne
25-09-2015 09:29 PM
Quick Reply: Cossie rad dimensions req
