Pic request please
Old Jun 27, 2004 | 05:42 PM
redfrst's Avatar
redfrst
Default Pic request please
does anybody have a picture of a s2 oil feed oil return and fitting please
Thanking you all in advance thank you
Old Jun 27, 2004 | 05:48 PM
Hatch's Avatar
Hatch
alrite m8 . dont think a pikky is needed its a short pipe elbow secured by 2 spring clips either end
Old Jun 27, 2004 | 05:50 PM
redfrst's Avatar
redfrst
so ther is one braided hose and a little rubber one correct
Old Jun 27, 2004 | 05:51 PM
Hatch's Avatar
Hatch
yea the braided is the feed from the back of the engine by the oil filter and the return is the plastic pipe below the turbo m8
Old Jun 27, 2004 | 05:53 PM
redfrst's Avatar
redfrst
im doing a conversion on my frst and need toknow what goes where
Old Jun 27, 2004 | 05:57 PM
Hatch's Avatar
Hatch
straight forward m8 . would of thought fiesta the same as S2
Old Jun 27, 2004 | 06:00 PM
redfrst's Avatar
redfrst
on the fiesta you have the oil feed running over the cam cover do you conect to that or do you go straight from the block or where ?
Old Jun 27, 2004 | 11:25 PM
StephenC's Avatar
StephenC
..BS Motorsport..
can make out the return off this pic. The oil feed comes from the back of the block (outlet with the oil pressure switch) via a braided hose to where the yellow bung is on this picture.
Old Jun 27, 2004 | 11:32 PM
redfrst's Avatar
redfrst
Which one is the return. Is that the one under the actuator going into the front of the block
Old Jun 27, 2004 | 11:34 PM
StephenC's Avatar
StephenC
..BS Motorsport..
you can make out the green gasket, thats the return, solid pipe going to flexible pipe with just a heat protective tape round it going to the block with just spring clips holding it either end.
Old Jun 28, 2004 | 12:03 AM
redfrst's Avatar
redfrst
ok sweet that rubber hose behind th actuator how long is it. I have on but its bout 2 inches long is this rite mate
Old Jun 28, 2004 | 06:14 AM
StephenC's Avatar
StephenC
..BS Motorsport..
dont want to split hairs but id say approx 3 inches
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
locum8
Oct 1, 2015 01:50 PM
