Warped disks... can they be fixed?
can you get slightly warped disks skimmed? if so where from?
dont fancy chucking away a perfectly good set of disks... theyve got a slight vibration when braking hard
not standard, theyre v. epensive disks
also all a disk is is a bit of metal, so if you make them flat again, then theyll be perfectly good
Are you sure it's not your TCA bushes worn slightly?
Are your hubs slightly out of true?
AMD and ABP Motorsport can reface your discs on the car using a PRO-CUT brake lathe so they run true taking into account any small intolerance. Tis not cheap though - about Ł40 a side so depends on how much your discs are.
i assumed discs coz when i bought them i got told they may be iffy (got the whole setup for 60quid so wansnt complaiming)
the outer tca bushes are new, as are the TCAs... the INNER tca bushes are not correctly mounted (m10 bolt, M12 hole... this gets fixed tomorrow so will see after that
oh and my tracking's a mile out
Russ Payne
25-09-2015 08:29 PM
Cos500
16-09-2015 09:50 PM
andrewmctiernan
08-09-2015 03:05 PM
