Twin charging an engine
Old 08-08-2005, 12:20 PM
RWD_cossie_wil
RWD_cossie_wil's Avatar
Default Twin charging an engine
Ok, I know its been asked before, but what issues are there with super-charging a cossie YB, as well as using the turbo as normal?? I recon with some non return valves and a suitible by-pass for the 'charger when the turbo comes alive and it should work perfectly once mapped?
obviously using a small charger to "fill in" the bottom end performance of a larger turbo would reap huuuuuuge benefits of drivability etc??
Old 08-08-2005, 12:23 PM
digita1dragon
digita1dragon's Avatar
Have a read through this, it may answer a few of your queries
PS you need about 6 hours free
http://forums.evolutionm.net/showthread.php?t=127361
Old 08-08-2005, 12:25 PM
fernando_khan
fernando_khan's Avatar
definitley possible! some bloke done it to an evo 8 in the u.s ..... he made his own valve for the switch over between the charger and turbo.
he was running a 2.3 stroker with maaaasive turbo that spooled 10psi by 8000 rpm normally... with the charger he was hitting the boost by 5000 rpm but with the charger coming on straight away awesome accellaration...
would be very hard to make and all parts would be custom but if it worked would be very cool!
Old 08-08-2005, 12:26 PM
fernando_khan
beat me to it!
Old 08-08-2005, 12:28 PM
Porkie
Porkie's Avatar
Been done a few times already on Cossies
Old 08-08-2005, 06:29 PM
RWD_cossie_wil
has it??? got any links/info please porkie?
thanx for the link as well Digi
09-10-2015 07:38 PM
oilman
Trader Parts for Sale.
30-08-2015 08:37 AM
Ben26
27-08-2015 08:56 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: Twin charging an engine
