pistons out... what parts required?
going to strip engine down at weekend... (1800 zvh)
What parts do I need so I can buy them now before it gets to the usual sunday panic! :cry:
headgasket & bolts
Sump gasket
oil
filter
antifreeze
cam belt
anything else?
headgasket & bolts
Sump gasket
oil
filter
antifreeze
cam belt
anything else?
I don't know what size the bores are until I strip it down.
I need to take it apart because when it was built apparently all the ring gaps were put in a line rather than the usual 120 apart and its passing oil big time. with only 120ish compression.
now it COULD just be a fooked bottom end etc in which case its going to be a bit more indepth than this quick pull apart job.
not sure how long its been together.... few thousand miles maybe? ive only done about 500 miles...
basically I run an open breather on it... If I don't it smokes like hell through the exhaust... but it chucks out of the catch tank about a pint every 100 miles!!
maybe the breather and return is a severe mess and not returning to the sump at all but something is definately amiss.
Ah right, yeah excessive crank case pressures sound like a possible symptom of ring aligment.
In which case fingers crossed you can just lift them up, move them, put them back down and they will be ok, i would rehone the bores and use new rings though personally.
I know its tempting.
But its another £75ish for rings for an engine of unknown quality.
I'm not overly fond of the ZVH engine and it could be £75 towards rebuild costs on the 1600 cvh.
I have a decent car for daily driver... a mk2 XR2 project car that I want to start getting my teeth into and this mk2 fiesta turbo that I just want to use for a few run what you brungs and A road weekend blasts.
It will no doubt turn round to bite me, as if youre doing a job may aswell do it properly but in this case I'll make that decision when its apart.
155lee
06-09-2016 11:10 AM
