Brakefluid question regarding ABS
can i just put in anything ? 5.1 any types? srf? etc?
cause the ABS is electrical so there is nothing i can fook up right?
Think the dot 5.1 and 4 are mixable as they are mineral but i would advise AGAINST it as they have different boiling points etc.But as a quick fix.YES As said above srf is synthetic so would have to drain system and refill with srf only.
thanks i am rebuilding my front calipers so the whole system will be drained anyway but last time when i needed a little bit the shop salesman told me not to get 5.1 as it would feck me abs .... but that wont be happing right as the abs is electrical ?
Basically there is a block of solenoid valves that bleed pressure out of the circuits as a wheel tends to lock. The kicking you feel in the pedal during ABS operation is caused by these valves opening and closing.
The control is certainly electronic, but the actual ABS mechanism is mechanical
Neil.
PS I dont think it makes the blindest bit of difference Been using DoT5.1 in my cossie for 3 years, and in my old ABS Sierra for nearly 7 years before that - Im sure it will be OK
Neil.
Neil.
Neil.
