Steering UJ Question
Old Aug 2, 2005 | 07:27 AM
Neil S's Avatar
Neil S
Default Steering UJ Question
I've got a knocking noise coming from the front end every now and again - it usually happens when I'm parking (so going slowly with a good bit of lock on). Its just one loud thump generally.
I've been underneath and checked the usual suspects (TCA's, Trackrod Ends, ARB, rack etc - even down to the crossmember bolts!) and the only thing I can find that is remotely iffy is some play in the lower steering UJ where it pinches onto the rack.
Is this normal, and do you lot think it could be the cause of my problems?
Cheers all!
Neil.
Old Aug 2, 2005 | 07:30 AM
RichardPON's Avatar
RichardPON
Coil spring broken, or knackered suspension top mount?
Old Aug 2, 2005 | 07:48 AM
Neil S's Avatar
Neil S
Springs look OK Rich, although I admit they only got a cursory look over. No play in the suspension tops when I push the wheels top to bottom either
Might drop the struts out tonight and check them over like.
Cheers Dude
Neil.
Old Aug 2, 2005 | 07:56 AM
RichardPON's Avatar
RichardPON
Default Re: Steering UJ Question
Didn't see this bit..............
Now that's a WHOLE separate question
Old Aug 2, 2005 | 08:08 AM
Neil S's Avatar
Neil S
At least my car drives
Neil.
Old Aug 2, 2005 | 08:15 AM
RichardPON's Avatar
RichardPON
Mate - few more days and mine will too
Old Aug 2, 2005 | 08:17 AM
Neil S's Avatar
Neil S
There's a funny echo in here.... You've been saying that since 2003!!!
Worse than the bloody weegie you are!
Neil.
Old Aug 2, 2005 | 08:18 AM
RichardPON's Avatar
RichardPON
Next year Rodney etc etc ..............
Old Aug 2, 2005 | 12:15 PM
Neil S's Avatar
Neil S
Anybody got any (sensible) suggestions?
Neil.
Old Aug 2, 2005 | 12:19 PM
Graceland's Avatar
Graceland
Team HOTHOT!
if your car is 4wd, you checked the outer CV joints? as these knock if they are worn when traveling at low speeds and using full lock
Old Aug 2, 2005 | 12:21 PM
Neil S's Avatar
Neil S
The outer CV's are new(ish), and it's not a rhythmic knocking, it's just one clunk
Cheers though!
Neil.
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
stevecfrst1
Sep 30, 2015 05:18 AM
