TECHI question
Old Jul 25, 2005 | 07:45 PM
BigNige's Avatar
BigNige
Default TECHI question
Why do diesels smoke so much
Especially with FOOT flat down
Nige
Old Jul 25, 2005 | 07:49 PM
EIL132's Avatar
EIL132
Diesels smoke because they are diesels. It's the fuel that does it and they ain't enviromentally friendly
Old Jul 25, 2005 | 07:52 PM
BigNige's Avatar
BigNige
but 50mpg is cool
But why do some smoke less
My audi seems ok unless you BOOT it and hold it
Sat behind a newish Chrysler voyager that was pumping shite out
NIge
Old Jul 25, 2005 | 07:53 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
i thionk its because of the carbon build up, some may build more carbon up than others in he exhaust, but mostly turboo diesels smoke more because the air is getting forced out harder thus blowing more carbon out
Old Jul 25, 2005 | 07:54 PM
roybacer's Avatar
roybacer
I've got a lightly modded 206 hdi (130bhp, remapped, k+n panel filter, full exhaust) and mine dont smoke to bad in general
The only time it smokes is if u floor it off boost, and thats because theres loadsa un burnt fuel
Old Jul 25, 2005 | 07:56 PM
EIL132's Avatar
EIL132
All diesels smoke under load, they are effectively oil burners, they use compression to burn it as opposed to spark. The new cats and stuff can help with getting rid of some of the shite. Might've been cold or rich also
Old Jul 25, 2005 | 07:59 PM
Rick's Avatar
Rick
Diesel is difficult to combust. WHat u see is reminents of incomplete combustion. Modern diesels use very high fuel pressure in order to get the power they do. Sometimes, a little too much is injected, and it's equivelant to running a slightly rich mixture - but it's far more noticeable with diesel. You can tune modern diesels to quite high power outputs by increasing the fuel pressure - but u start to get lots of visible smoke.
Old Jul 25, 2005 | 08:39 PM
AlexF's Avatar
AlexF
Diesels NEVER run rich!
They smoke more due to the fact that you spray diesel into really hot air. The only point of combustiong is when air is mixed with the diesel...
So you inject very hard (high pressures and small nozzels) to make the spray as fine as possible. But you are still relieing on air movement to mix the air and fuel so it burns.
Some engines smoke less than others for one main reason - combustion chamber design!!
Alex
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
