Headlights!!
Old Jul 24, 2005 | 06:48 PM
Trev's Avatar
Trev
Default Headlights!!
Right peeps need some help- put my headlights on sidelight all fine turn to dipped and the things go dimmer??? full beam is spot on?
Whats wrong is a s2?
Where should I start looking?
Trev
Old Jul 24, 2005 | 07:15 PM
Al Bags's Avatar
Al Bags
Dipped beam fuse contact resistance or same problem in the column stalk unit.
Check fuses first, then the column stalks ... is my tip!
Old Jul 24, 2005 | 07:21 PM
xr4x4rs's Avatar
xr4x4rs
check the two either brown or white little relays at the back of the fuse box
there together wiggle them
more than certain its them mate
Old Jul 24, 2005 | 08:25 PM
Trev's Avatar
Trev
mm thought it would be relay related - are they all the same on the escort range?
Old Jul 24, 2005 | 08:28 PM
Spax's Avatar
Spax
Had this on my S2,Turned out to be the relays blowing and melting,had to keep replacing them at £7 each got expensive....then they just didn't work at all,the fusebox had melted,needed a new one really,but thought nah sod it and never fixed it,sold it last week for the poor guy to sort out now lol
Old Jul 24, 2005 | 09:11 PM
xr4x4rs's Avatar
xr4x4rs
what it is i think is through vibrations the relays move and the pins where out
the best idea i seen was what poom did and just put a bit of solder on each of the pins so that that fatter and get a better connection
he hasnt had any probs yet
but any mk3/4 are the same relays
just two little ones
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Nov 1, 2015 06:53 PM
Steve Escos
Oct 1, 2015 06:57 AM
mondeomark
Sep 28, 2015 06:28 AM
Kam B
Sep 24, 2015 10:40 AM
