anyone know?
Proven Legendary Status
Just a little extra info. (going from memory)
IIRC The 4x4 calipers and mounts will bolt straight onto the S1 hubs. But you'll have to use 2wd discs. Because of the offset. You "may" find you need to shim the caliper a little to get it all to line up centrally.
Other alternative is to drill out your hub and retap it for the M16 (2wd) caliper to bolt straight on. Not sure which Discs you'll need for that but i think. Ian will be able to advise you. (Not used his services)
