How do you take the front diff off a escos?
Guest
Posts: n/a
Yes you can but you need to remove the shalf from the other end of the sump.
Disconect spedo cable unbolt 3 bolts and remove cup. Then take out 2 clips and remove shaft.
Your need to undo bottem ball joint on right side then pull out drive shalf.
Once that is all done remove 3 bolt that hold diff in place then slow wiggle towards you and job done
Last time l did this l broke to fingers so be carefull mate
Dave
Dave
james kiely
28-08-2015 08:58 PM
