FAN PROBLEM ON COSSIE
Old 21-07-2005 | 11:10 AM
IANS2RST's Avatar
IANS2RST
Default FAN PROBLEM ON COSSIE
fitted another pair of fans at the weekend to my car as only 1 was working.
last night noticed that they wern't kicking in.
checked this morning thinking fuse relay or wiring but all were ok.
jumped power to the fans an nothing happened , neither are seized. would have thought it possible that 1 fan could just pack up but both together seems unusual .
anyone got any ideas before i replace them again?
Old 21-07-2005 | 02:48 PM
IANS2RST's Avatar
IANS2RST
anyone?
Old 21-07-2005 | 03:06 PM
Stealth Bomber's Avatar
Stealth Bomber
Had endless problems with the fans on mine, not kicking in when they should, in the end my mechanic figured it out but not sure what, think the wires end up needing replacing.
Old 21-07-2005 | 11:10 PM
DazC's Avatar
DazC
Did you give the fans direct live and earth feed?
Old 21-07-2005 | 11:15 PM
EssexBoyRacer's Avatar
EssexBoyRacer
probe around with a volt meter and if pos try running a 12v supply straight to the fans to check they work.
Old 21-07-2005 | 11:24 PM
escortrsmatt's Avatar
escortrsmatt
my fans werent working either, try bridging the fan switch on the bottom of the rad.if that doesnt work try bridging across the relay in the fuse box.(relay should be yellow)mine worked intermittently for a while and found out it was the relay gradually frying itself!!gave up after a while.
Old 22-07-2005 | 09:58 AM
IANS2RST's Avatar
IANS2RST
nope tried all this, fans do not work with a direct live & earth, there is power to the fan switch & no breaks in the wiring, the fans have just stopped
Old 22-07-2005 | 10:00 AM
EssexBoyRacer
So you've removed the multiplug and fed the fan side of the plug with a direct +ve and -ve?
Definately your problem is with the fans or the wiring between the fans and that multiplug then.
natehall
Ford Focus (All Models)
08-09-2015 06:13 AM
Adam Graham
06-09-2015 07:04 AM
wheelwizardrefurbs
05-09-2015 11:52 AM
Quick Reply: FAN PROBLEM ON COSSIE
