RS2000/XR3i Rear beam with discs - is it hard to fit???
In theory it should be more or less a straight swap. It's the fact it's a large item that means you could do with a second pair of hands.
Just hope you don't get any siezed bolts...
Baby Cheesus
you can either just undo the 4 bolts on each stub axle, drill out the 2 rivets for each backing plate for the discs, then bolt straight up to the the drum beam, or you can compltely reomove the beams and do a straight swap.
you will need a mk5 rs2k handbrake cable too.
not to too hard to really
155lee
14-09-2015 07:37 PM
155lee
14-08-2015 11:21 AM
track.focus'd
12-08-2015 05:53 PM
