Boost restriction!!!!
Old Jul 8, 2005 | 10:55 PM
rsjohn's Avatar
rsjohn
Default Boost restriction!!!!
On a cossie engine is there anyway the engine itself would restrict the boost level????
john
Old Jul 8, 2005 | 11:35 PM
the strut brace's Avatar
the strut brace
think a p8 ecu has a restrictor if summits wrong with the engine/sensor, limits it to 4k i think
Old Jul 9, 2005 | 12:11 AM
rsjohn's Avatar
rsjohn
I dont mean electrics i mean just the engine itself, mechanics.
john
Old Jul 9, 2005 | 12:34 AM
rapidcossie's Avatar
rapidcossie
revs and boost is cut at 7k revs i think on standard management
Old Jul 9, 2005 | 08:21 AM
rsjohn's Avatar
rsjohn
No!!!
Basicly iv changed the engine in my cossie to low comp, T34, greys etc now i cant get anymore than 18psi out of the engine and thats nearly at rev limit, i have changed actuator and checked for ir leaks etc.
Before i changed engine it was running stage 3 at 26psi.
I have also looped turbo with a bleed vlave and still only got 20psi at high revs, it doesnt start boosting til 3-3500rpm!!
any info apprerciated please guys
john
Old Jul 9, 2005 | 08:25 AM
the strut brace
silly question but is the turbo housing/ exhaust all nice and tight? bit out of my range mate
Old Jul 9, 2005 | 08:30 AM
Stu @ M Developments's Avatar
PassionFords Creator
No prload on actuator (min 3mm) or a Cracked wastegate is very likely, after ruling out simple things like leaking dump valves and pipes etc of course.
Old Jul 9, 2005 | 08:39 AM
rsjohn's Avatar
rsjohn
Have put preload on actuator, taken off dumpvalve. I have fitted new pipes from actuator and turbo to amal, iv even changed amal valve.
i hope its not cracked wastegate as bought the turbo off someone on this board and he said had only done 1000 miles!!!
john
Old Jul 9, 2005 | 08:51 AM
the strut brace
thinkin again john, stu had this prob with mine and it turned out to be the join where the 2 bits of the 2wd exhaust manifold join, 2 bolts had fallen out and the manifold was flexing under load and leaking like a twat, juat a thought
Old Jul 9, 2005 | 08:53 AM
rsjohn's Avatar
rsjohn
Oh right, i have fitted a 2wd exhaust manifold to my 4x4 but all nuts and bolts are tight as not long ago fitted it all!!
john
Old Jul 9, 2005 | 08:55 AM
the strut brace
mine came slack on the drive to stu's if you havnt used the correct bolts coz they apparently are special ones or summit they just come loose quick as fook
Old Jul 9, 2005 | 08:56 AM
the strut brace
john out of interest how did your 2wd manifold fit with it being 4x4 as the exhaust woiuldnt go on my turbo when i did it and i had to change it back think i need a bit weldin on the exhaust to make it higher
Old Jul 9, 2005 | 09:11 AM
rsjohn's Avatar
rsjohn
the bolts are proper ones.
Had to disconnect exhaust from down pipe the refit, its tight under gearbox but ok.
I have mongoose system.
john
Old Jul 9, 2005 | 09:18 AM
peteh's Avatar
peteh
how about sending my parts?
Old Jul 9, 2005 | 07:37 PM
rsjohn's Avatar
rsjohn
Bump
john
Old Jul 9, 2005 | 08:32 PM
Fiecos Dan's Avatar
Fiecos Dan
try wire'in up the actuator, and in say 3rd /4th gear bring boost in usin the brakes and throttle, (be carefull, dont cook the brakes, or do it for more 5-10 seconds, and dont go past 25/30 psi boost)
if even at 4.5 k rpm still not hitting proper boost then, could have
blocked zorst,
crack in turbo, or mani leak,
air leak, have you pressure tested whole system to 30 psi?
cam, or cam timin problem
Old Jul 9, 2005 | 09:49 PM
CharlieSaff's Avatar
CharlieSaff
actuator fooked?
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
