Escos - dashboard strange behaviour
Old Jun 21, 2004 | 09:16 PM
Azrael's Avatar
Azrael
Default Escos - dashboard strange behaviour
I just returned home from a small ride and I had strange situation one moment. I had really hard braking to a corner and after that all th ilumination of the tacho, speedometer and other things - like boost, voltage and oil pressure just dissapeared with an exception of small spot of light in the middle of the speedo. After stoping and switching ights on and of a few times and moving the brightness regulator everything came back to normal. What was that???
Old Jun 21, 2004 | 09:31 PM
Big Andy W's Avatar
Big Andy W
Illumination voltage regulater has a bad connecti0on!! I'm pissed but trust me itthe elecftro luminesent box is going bust! the small light is the standard bulb for lightin mileage! not linked to lum inesent control box!
Old Jun 21, 2004 | 09:43 PM
Azrael's Avatar
Azrael
So, how can I prevent this from happening in future? Everything is working great and I am told my clocks look much better then on most Escos, apart from that incident. Schould I worry?
Old Jun 22, 2004 | 08:11 AM
T38Mat's Avatar
T38Mat
Mine did the same - diagnosis is correct.
Old Jun 22, 2004 | 08:22 AM
Azrael's Avatar
Azrael
Could you please tell me if I am to look for new clocks or repeir something? I can't really understand sometimes what you mean....
Old Jun 22, 2004 | 07:09 PM
Damo V's Avatar
Damo V
Where exactly id tyhe voltage regulator located?
Old Jun 22, 2004 | 07:14 PM
Fozy's Avatar
Fozy
The voltage reg is soldered on the back of the pack and then zip tied. Mine have gone and took a look the other day. Doesn't look that hard if you're handy with a soldering iron.
Old Jun 22, 2004 | 07:20 PM
Damo V's Avatar
Damo V
Cheers Fozy
SO what just pick up a new votage reg from Ford? Bout 70 quid aint they any FINIS numbers?
Old Jun 22, 2004 | 07:33 PM
B11GNS's Avatar
B11GNS
Had the same problem on my womans old escort, it was indeed the v/reg, ordered new board from ford, as said above about Ł70 but it took ages to come through due to the part being made came from a small company hence the time i had to wait
Old Jun 22, 2004 | 07:34 PM
Orionzetec's Avatar
Orionzetec
The instrument dimmer switch thingy is finis: 6833787 Price is Ł19.63
Not sure if this will fix the problem though
Old Jun 22, 2004 | 07:39 PM
B11GNS's Avatar
B11GNS
No it isn't this, it is the part described above as i have encountered this very problem and replaced the part myself and it is about Ł70 from fords
Orionzetec's Avatar
Orionzetec
If its the illumination board thing then the finis is: 6748813 for 04/92-10/93 cars and 7003674 for 10/93-01/95 cars
Old Jun 23, 2004 | 07:28 AM
T38Mat's Avatar
T38Mat
TurboSystems fixed mine. But its old board out and new board back in and thats it - Good luck! The problem will get worse if u leave it and driving at night with no illumination is not very useful.
Mat
Old Jun 23, 2004 | 09:45 AM
EssexBoyRacer's Avatar
EssexBoyRacer
Ł70!!!!! halfords sell an EL inverter that performs the same job for a fiver!!!!
Old Jun 23, 2004 | 10:00 AM
Jobbo's Avatar
Jobbo
Mine did the same, Duncan at Automotive put in a new one, cost me about 60 squid, Give him a call, it was done in a couple of days.
Old Jun 23, 2004 | 10:03 AM
Jobbo's Avatar
Jobbo
Sorry Dude, didn't realise you were in Poland.
I'ts been a hard week!!!
Old Jun 23, 2004 | 10:09 AM
Azrael's Avatar
Azrael
No problem at all... It's really making me mad sometimes that I can't do things as easily as you. But I can drive much faster
Anyway, you all tell me that I am going to have to change the voltage regulator, am I right? Cleaning or anything like that wont help.
Old Jun 23, 2004 | 10:14 AM
richgander's Avatar
richgander
Default Re: Escos - dashboard strange behaviour
I had the same problem with my large turbo escort, you need to remove your main clocks containing the speedo etc.. Then open it up, you will see a small quite narrow electrical board, this is what is causing your problem, remove this (very carefully) get the numbers off it and Ford should get you one in a day or so for about Ł60 quid, also the small amount of light you are getting is from two regular bulbs put there incase the board fails.
Old Jun 23, 2004 | 10:15 AM
Jobbo's Avatar
Jobbo
I tried cleaning it up, but this did absolutely nothing, Mine were on and off like a tarts knickers, it's worth the money you pay to have it done Dude. Good Luck.
richgander's Avatar
richgander
Old Jun 23, 2004 | 10:27 AM
Azrael's Avatar
Azrael
I think only one bulb works - will change it.
I'm thinking about cleaning it because the problem apeared after a giant flood I had in my Cossie when one of the waterpipes from sunroof came loose - all the water flooded through electric things on the left side of the car (LHD). Maybe something just became dirty. Must check it, and probably buy the thing eventually.
Old Jun 23, 2004 | 06:24 PM
Damo V's Avatar
Damo V
I shall be stripping my clocks soon
Thanks very much people
Old Jun 23, 2004 | 06:44 PM
Azrael's Avatar
Azrael
Mine just stopped iluminating at all :-(
Old Jul 22, 2004 | 11:13 AM
Damo V's Avatar
Damo V
Just been to my local dealer and ordered one of these.... comes complete by the looks of it, Ł71 quid..... hope it works!
Old Jul 22, 2004 | 11:24 AM
Azrael's Avatar
Azrael
I got it, just have to convince my electrician to change it because he says its not it :-/
Old Jul 22, 2004 | 12:04 PM
Daveyraveygravy's Avatar
Daveyraveygravy
On the Mk 5 & 6 escorts it is VERY common to find water making it's way down the A-pillar onto the tracks in the fuse box, and the soldering looks like it has been done by a trained monkey anyway!. This could cause a whole lot of very funny faults. My friends Escort had the washer jets come on for no reason, stutter at 4k RPM, Sudden stalling of the engine - then it fired up again?!?!? Window switches controling the wrong windows, e.t.c, e.t.c So if the voltage regulator doesn't fix it, that would be my next bet.
Hope you get it sorted
Old Jul 22, 2004 | 12:19 PM
foreigneRS's Avatar
foreigneRS
Testing the future
no mate, it was done by untrained monkeys
Old Jul 22, 2004 | 12:27 PM
Damo V's Avatar
Damo V
Yeah the newer fuse boxes are alot better, mine has been replaced
Old Jul 22, 2004 | 01:41 PM
Paul Eggleton's Avatar
Paul Eggleton
Ah, this maybe the cause of my rear washer jet coming on when i use the fronts
ta
Old Jul 22, 2004 | 01:46 PM
DaveEscos's Avatar
DaveEscos
how easy is it to replace the fuse box?
any soldering to be done?
or is it simply unplug , unclip and fit new one?
Old Jul 22, 2004 | 04:32 PM
Azrael's Avatar
Azrael
I have the same, but I suppose it may be a problem with the pump itself. It schould pump only one way at the time and it doesn't.
Old Jul 22, 2004 | 05:14 PM
Damo V's Avatar
Damo V
Piece of piss Dave, You will DEFO be able ot do it I reckon, just bolting no soldering, I was very suprised mate, took me about ten minutes, the 4th time round lol (ford gave me the wrong ones first)
Micro cat listed the wrong ones for my car... mine was near 200 quid, but the ones which were wrong were alot cheaper and will prob be ok for yours
Just be sure to get one with the same 3 letter code next to the big long 94ABblah blah number
the 3 digits will be, abb BBA BAB BCA, something along those lines mate, Dont mind bolting it up for ya if not sure, just make sure battery disconnected
Paul, I reckon your switch assy is at fault, about 60 quid IIRC from Ford, IIRC, there are 2 pumps on the washer bottle, one for front one for rear so dont think it will be that....
Old Jul 22, 2004 | 09:21 PM
Azrael's Avatar
Azrael
On Escos there is one for the front and rear and one for headlamps!
155lee
Oct 24, 2015 11:11 AM
gcfcos
59
Oct 6, 2015 05:04 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
Mickeystewart
Sep 9, 2015 04:04 PM
