MOT fail
Help Help
My rst failed today- not a lot of stuff but....
Anyway bits im not sure on the steering coloumn has movement in the top bush so needs replacing how easy to do? can anyone give me advice on changing this?
Also rear wheel bearings , ive never changed these do I need any special tools?
other bits and bobs I can do but the above am a bit stumped, oh yeah the good bit I have 7 days
Trev
Trev
dunno about steering bush mate but the wheel bearings a doddle i think its a 24 socket mate, make sure handbrake is off, take out split pin then nut and the rear drum should slide off with the bearing thats it mate if i can remember rightly
steering colum bush is a pain to fit afaik, up under the dash?
rear wheel bearings, no special tools requiered, but you have to get the nuts on the right tightness, not too tight and not too loose. . best leaving that to someone who's done it before!
mm haynes manual me thinks - need to get that ticket,
list so far to do
* headlight switch as lights keep going on and off on their own
* Steering column top bearing
* nearside indicator bulb
*both track rod ends
* both rear wheel bearings
* brake hoses not secured to strut both sides
* drivers CV boot split
* cracked front numberplate
list so far to do
steering column not to bad to do mate i did one on mine is it definatly the top bush
as the lower one is plastic and they tend to wear causing the same problem
have a wiggle of the centre column shaft at the bottom just above the pedals
aee if the shaft moves in the black tube then its the lower bush
best of luck
best of luck
SMILER258
Sep 28, 2015 09:04 AM
