Whats the importance of getting the plug gap right?
As above. Up until now I've always just put a new set without any adjustment but having read a few posts it seems as though they need to be adjusted.
Would really like to know the technical stuff.
Ideally you want as big a gap as possible in order to get the burn started as quickly as possible, but on the other hand a smaller gap is less likely to be overcome and "blown out", so its a bit of a balancing act, generally though a decent coil will allow you to run more boost without having to close the gap up.
Originally Posted by james_birch
does anyone just put theres plugs in from the box? as i do
Some plugs like some modern iridium ones you cant really gap yourself, they are too fragile, but you can still check them and know to not fit one or two if they are wrong.
deathrider666
28-09-2015 06:12 PM
