scooby question
Old Jun 25, 2005 | 07:43 PM
martinmace's Avatar
martinmace
Default scooby question
does anyone here know anything about imprezas cos no fucker on the subaru site seem to know a lot at all so i thought i would ask you clever lot if you can help please tell me you can and i wil tell you whats wrong thankyou very much
Old Jun 25, 2005 | 08:01 PM
martinmace's Avatar
martinmace
come on peeps dont b like that i still own a ford
Old Jun 25, 2005 | 08:03 PM
MK5RST's Avatar
MK5RST
Post the problem and your more likely to get a reply mate
Old Jun 25, 2005 | 08:04 PM
dave green's Avatar
dave green
I no a bit whats wrong?
Old Jun 25, 2005 | 10:50 PM
martinmace's Avatar
martinmace
the car wont idle under 2500rpm but if i squeeze the breather pipe next to the maf sensor it will come down according to how much you shut the air flow off???????? its a 93 wrx if this helps
Old Jun 25, 2005 | 11:04 PM
MK5RST's Avatar
MK5RST
Hmm, split breather pipe causing air leak?
Old Jun 26, 2005 | 12:13 AM
cossie1's Avatar
cossie1
sounds like an air leak to me m8
I have a similar problem with mine, however I was told by local scooby specialist to remove the intercooler and check the gasket on the back of it as this is a common problem with them.
The other thing to check is the maf itself, with the engine running, disconnect it, and see if the engine cuts out (mine does) which means the maf is working fine, but if yours doesn't cut then this might well be your problem.
HTH
Old Jun 26, 2005 | 07:31 AM
martinmace's Avatar
martinmace
thanks i will give that a go.
Old Jun 26, 2005 | 09:23 AM
dave green's Avatar
dave green
Sounds like the idle control valve to me , take it off and clean it with carb cleaner, should work fine then , may have to drive it a few miles for it to work OK.
They are expensive to buy new about £300
Dave
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
