lowering mk4 escort van???
just me van and lookin for sum info on couple of things but mainly lowering the rear.
i know u move the axle to above the leafs to lower it, but rumour has it u need special brackets costin 60 notes ???? anyone know wat they do/look like or where they can be found ?? if i knew would prob be able to make em dependin on wat they are?? any help appreciated!!
other thing was, how to wire up the tacho from xr clocks to work with the 18 derv??? cos obviusly there aint to coil!!!!
cheeRS Pf guys n gals!!!!
you coul dprobably get the leaf springs decambered for 60 quid. That would do the job nicely! Alternatively, you'll need lowering blocks with longer bolts to locate the axle, but I'm not sure what setup mk3 vans have so i can't really help there I'm afraid. Best bet is the decambering i reckon!
