formatting PC's
Old Jun 22, 2005 | 08:10 AM
Westy's Avatar
Westy
Default formatting PC's
hi all
just a quicky.. i need to delete all the stuff off of a load of PC's??
is there a quick and easy way to do this please???
Old Jun 22, 2005 | 08:13 AM
zvhturbo's Avatar
zvhturbo
Type in "format" in a help file and it will tell you how to do it.
Old Jun 22, 2005 | 08:14 AM
Joris_FRST's Avatar
Joris_FRST
Hammer and a nail through harddisk if it needs to be removed permanently
Otherwise make a bootdisk that auto starts and formats the HD (you can put switches in the command not to ask you to type anything).
Or ghost an empty disk over it if it needs to be NTFS
(format one properly, then ghost it)
Westy's Avatar
Westy
quality..
i have about 20 of the fookers
think the best way, is one monitor, then just change the tower bit each time..
thanks for the help
Old Jun 22, 2005 | 08:15 AM
Westy's Avatar
Westy
joris..
appreciuate that, but to be honest.. i havent a clue what you are on about
basically, we are getting rid of loads of PC's to charity etc, and dont want our info on them.. nothing needs to be saved
Old Jun 22, 2005 | 08:20 AM
Petrucci's Avatar
Petrucci
you only need to boot on the Windows XP CD mate, that will be the simpler for you if you don't know how to do those kind of things
Just select "install Windows XP", and the next step will ask you if you want to format the HDD or not.
Old Jun 22, 2005 | 08:21 AM
Westy's Avatar
Westy
oops
Pet mate, these are the ones before XP's time.. think they are win 98
Old Jun 22, 2005 | 08:24 AM
Petrucci's Avatar
Petrucci
boot on the Windows 98 CD, select "start the computer with CD-ROM support" (or whatever, i'm translsating literally from french so the menu name could differ a bit) and when you have the prompt, just type in format c: . (assuming ' c ' is the drive you want to format )
that's all
Old Jun 22, 2005 | 08:27 AM
Westy's Avatar
Westy
so i need the CD that you use to put win 98 on then?? its all on mate, i wont to take it all off
thanks Petrucci.. helps appreciated dude
could i not just got into windows, select C: and hit the delete button? or does it not work like that
Old Jun 22, 2005 | 08:31 AM
Petrucci's Avatar
Petrucci
how could a drive that's currently running an OS like windows format itself while working mate ? it's like asking someone to eat himself entirely
the simplest solution if you don't want to use any CD nor floppy is this. Boot the PC, then after the BIOS screen, press "F8" until a menu appears (the one where you can also choose "safe mode" if you see what i mean).
On this menu, select "command prompt" , then you're done... once you have the prompt, type in format c:
Tis the same as what i said above, but you don't need the CD then. But careful mate, if you don't have any Windows CD, how will you reinstall your OS after formatting ?
Old Jun 22, 2005 | 08:39 AM
Westy's Avatar
Westy
that makes it easier for me to understand mate
The purpose is, so that, once they are gone, they are totally blank... But slight change of plan Would like now to keep, Word, Excell etc, just no other details
Old Jun 22, 2005 | 08:40 AM
Petrucci's Avatar
Petrucci
lol so definately DON'T format mate.
Old Jun 22, 2005 | 08:43 AM
Westy's Avatar
Westy
everything I do always goes wrong anyway
whats the best way to keep, Word, Excell etc (standard programs) but delete the rest of it??
thanks
Old Jun 22, 2005 | 09:27 AM
Westy's Avatar
Westy
any ideas people?
Old Jun 22, 2005 | 09:54 AM
Joris_FRST's Avatar
Joris_FRST
Not possible.
Do one clean installation, windows 98, word, excell, ... Then ghost it to all pc's.
If they are branded pc's they might have a cd with an utility to put them back to how they were factory delivered.
(compaq is a cd, old dell is zztop utility, some newer is F12 when starting up pc, then choose option, ....)
Best option is to get someone to help you that knows more then the "on" button though, otherwise you'll be working ages on those 20 pc's.
Old Jun 22, 2005 | 10:00 AM
Westy's Avatar
Westy
cheers joris, i think
i really dont understand.. im just going to remove certain bits in explorer i think
Old Jun 22, 2005 | 10:19 AM
Where do you work Westy?
If the PC's have had work data on them, I would remove the hard drives and destroy them. Can't be too careful these days..!
Formatting won't wipe them securely enough..
Means the shops will have to sell them without HDD's but better that than someone buying them up and trawling through your company data and accounts
Old Jun 22, 2005 | 10:23 AM
Westy's Avatar
Westy
these pc's are going to freinds and stuff mate, so no need to actually take the hard drives out
just want it so that word and stuff is on, but nothing else? but it seems like a difficult task now
Old Jun 22, 2005 | 10:39 AM
saff_cossie's Avatar
saff_cossie
safest way is to format and reinstall the Operating System and Office if you want word and excel. Just deleting the offending files from the hard drive is not a safe way to do it as they are too easily recoverable.
Just find the Windows 98 Boot disk and the Office CD and away you go
Old Jun 22, 2005 | 10:45 AM
Westy's Avatar
Westy
cheers Bruce i have sent you a PM as its beginnig to get abit embarrassing on here
Old Jun 22, 2005 | 10:47 AM
St3V3_C's Avatar
St3V3_C
Westy, Re-formatting your computer won't get your sig back mate, I'm sure of it
Old Jun 22, 2005 | 10:49 AM
Westy's Avatar
Westy
thats not helping
im thinking of threatening to leave but i doubt it'll make any difference at all
St3V3_C's Avatar
St3V3_C
Sorry.
Old Jun 22, 2005 | 10:50 AM
Westy's Avatar
Westy
actually, Im holding a protest outside Stu's soon... also taking my Sig with me to GT battle on Saturday.. need as many sigs off of people as possible.. One love
Old Jun 22, 2005 | 10:52 AM
saff_cossie
PM'd you back Wendy
Old Jun 22, 2005 | 10:55 AM
Westy's Avatar
Westy
Old Jun 22, 2005 | 11:12 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
FPMSL and ROFLOL - Best quote I've seen in a looooooooong time
Old Jun 22, 2005 | 11:17 AM
RANJ's Avatar
RANJ
fdisk and kill the partition
Old Jun 22, 2005 | 11:22 AM
Westy's Avatar
Westy
sssttrrroooooooooooooooff, crikey, Bruce has sorted it for me via PM I know understand.. thanks all
and cheers Ranj, that may as well have been wrote in russian pal
Dazts1
Was It You?
Aug 2, 2015 06:44 PM
Old ford
Jul 31, 2015 06:50 AM
Matt
Feb 27, 2005 05:04 PM
Dec 17, 2004 10:53 AM
jayRS
Nov 19, 2004 05:50 PM
