help required essential gauges?
none IMO.
But i think in all honesty, if the engine its built properly there would be no need for guages.
And if you had guages i think they would make you paraniod.
Say you loost oil pressure and it showed up on the gauge, that second it took for you to look at the guage the damage is certainly almost already done.
All my opinion of course
Ryan, the SPA oil pressure gauge will beep or flash a brightly coloure dred LED if oil pressure drops and im sure others will also
what indication would you get if oil pressure dropped and you had no guages
and oil pressure could drop due to a failed hose, when the engine could be built and work perfect
and oil pressure could drop due to a failed hose, when the engine could be built and work perfect Trending Topics
rudey for you i think a speedo,,,,,,,,,,, fooking hoooge one too
for a cossie the most important gauge is the petrol gauge
ryan thats in extreme situations, but if it drops slowly then ya got the chance to sort it, imagine the engine oil never got to temp or ya sump had a leak, they would help ya out alot
sump gasket wouldnt affect oil pressure unless it stupidly low.
What difference is an engine in our car to an engine in any other car?
and you should notice the huge oil patch on your drive if you have that bad of an oil leak
Originally Posted by b19bal
how much are the SPA gauges
All depends on what you want, and often in addition you need a thermocouple which adds to the price aswell!
Great guages though!
Guest
Posts: n/a
ryan thats just no help so parts dont wear out temps dont rise bang!! you coulda saved your 10k engine if only you had an early warning system
not vulcan your not are you totally ilogical
the gauges im going for are atension grabbing they make farting noises so i dont have to look at em
thier just sooo expensive i dont want the full set
http://hp.autometer.com/products/nexus/index.html
so
egt
boost
oil pressure
water temp
what about oil temp?
thier just sooo expensive i dont want the full set http://hp.autometer.com/products/nexus/index.html
so
egt
boost
oil pressure
water temp
on a n/a car oil pressure usually isnt a problem, and the oil pressure light is ok !
on a turbo car, there aer oil feed/return hoses which are prone to leaking/bursting and the loss of oil pressure is very fast, so an additional guage is probably wa wise move!
boost guage helps if the car isnt going proper, overboosting, can see how much and if it is, etc
AFR guage, can tell if the car is getting the right fuel-air mixture, again not much of a prob on N/A cars
there not Essential, but all help and keep peace of mind to tuned cars which are more prone to breaking
IMO
They've got 10 people watching those monitors though, you've only got 2 eyes and there supposed to on the road not the gauge
F1 engines are a little different to ours. F1 engines are pushed past there limits and then taken back a degree so there completely on the edge.
99% of people cant afford to run that sort of a risk with their engines, so are far with alot more accetable limit.
Im not saying gauges are a bad thing, far from it. But if people spent the 100's of sometimes 1000's they spent on their guages on the engine being built to an even higher workmanship standard they alot of the guages wouldnt be needed
Once again all IMO
Once again all IMO
wowk
Mar 30, 2021 07:49 PM
Mark RS
Oct 12, 2015 06:01 AM
