glue for silicone hose...
Hi,
I need a glue / adhesive that will stick to a silicone hose ! I've tried HV350, araldite etc... They set ok but as soon as you flex the hose it all flakes off Also it must be able to with stand heat....its for a water temp sensor that I've drilled and screwed in the hose, it sits really tight in there but I want to seal it up properly before putting it on the car. Anyone any ideas as what to use ???
Cheers, Duncan
Cheers, Duncan
have u tried silicone?
If that dosen't work, anyone else any ideas, it will have to be flexible as well.
Duncan
why not do the job properly, get a proper T-piece the correct diameter of your water hose and drill & tap into it for your water sensor. Then mount the T-piece into the hose using jubliee clips to make it all water tight?
Vacuman
22-09-2015 12:09 PM
