T5 - 2WD Clutch Options
Sounds like my Release bearing has given up....
Using a standard cover with an alcon plate...
What other options are decent for 2WD
That old set up was fine for 370-400bhp - But not for 450-480 LOL....
Triple plate ? Costs
AP Group A ?
AP Group A ?
i got mine less than a yr old
got 2 brand new ap 6 paddle plate
2 brand new 3 paddle plates
and 2 good plate that are in it
£450
plates are £85 each new so ya nearly getting the clutch for free
£450
Caraholic
Steve,
Given the low weight of your car, you should be fine with the Alcon clutch AND cover (will improve the life / feel dramitically if you hydraulic it as well ) at this power level.
With my Sapphire, I never had any problems with this clutch and that had 515bhp (flywheel) and weighed 1275kg.
Mike you speak like Hydraulics is a new thing LOL...
Had a hydraulic clutch for about 4 years LOL....
So if I get a new cover and release bearing as the plate has only done 1500 miles....
Might be worth getting the lot LOL
OK brom
OK brom
Steve,
It IS unusual for Cossies .
Can't believe you tried to put a crappy standard cover in though and then expected it to do anything with 400bhp .
Worked Below 400 so unless you have tested this in a mk2 how do YOU know LOL....
So cheap alcon cover required
