mental builds in progress?
Old 17-06-2005, 03:42 PM
  #81
ze-vh phil
ze-vh phil's Avatar
ah the good old t34, i love mine.
not only do they look the spuds squized in but such a better power delivery than the t3
and thats always a good thing
Old 17-06-2005, 09:18 PM
  #83
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
Originally Posted by MADRod
Originally Posted by BROM@ZOO
got nothing to prove
its a demo car for zoo thats it
no one will be doing top speed runs now at brunters due to the 86 limit on noise
no car with over 600bhp will b less than that
look at prokie at bedford 1 bar of boost all he could run
Ive already booked my Topspeed record attempt date & it aint at Brunters 0r Elvington .
without taking anything away from what you are trying to achieve... i think that once you move your attempt away from brunters it then becomes hard to compare the record to others. for example i did just on 200mph in my mondeo about 3 years ago but because i had a 3 mile run at it and 50 miles to stop i said nothing, my car will be doing its top speed run on a 6 mile straight if that’s the case! not in the uk but if the goalposts are being moved..........
Old 17-06-2005, 09:42 PM
  #84
ImaRacing 700
ImaRacing 700's Avatar
Thats the thing really...if the track is longer than Brunters then how can you fail ? Hell mine will do over 200mph on a long enuff test track!
I didnt realise Brunters is now a no go So my attempt with a screamer pipe let alone more than 1 bar is a no go
Old 17-06-2005, 10:06 PM
  #85
CozzyBrom
CozzyBrom's Avatar
rod am not saying no will will try
what i am saying is 1st test run to set everything up ya run the strip and then get told to go home becuz you have gone over noise limits
if a 2 lt engine is pushing out well over 650 bhp with out gas then i carnt see any exhaust keeping it below 86
i not a expert in these fields but personlly i canrt see it passing the noise
good look anyway
Old 17-06-2005, 10:19 PM
  #86
Brunters is dead im afraid so new venues have to be found. I would be interested in the 6 mile straight or even a 3 mile one in this country.
Longest ive found is 2 miles which gives 4secs longer on the throttle @ 200mph than at Brunters.
Rod
Old 17-06-2005, 10:21 PM
  #87
ADUSR33
ADUSR33's Avatar
and dont forget rod will be the first cozzy to clock 80,000 mph
Old 18-06-2005, 12:19 AM
  #88
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
Originally Posted by ze-vh phil
ah the good old t34, such a better power delivery than the t3
A T34 Esc Cos Turbo is a T3?
Old 18-06-2005, 01:34 AM
  #89
ze-vh phil
ze-vh phil's Avatar
well my t34 is alot bigger than my old t3 and the power delivery is different
Old 18-06-2005, 06:45 AM
  #90
Versus_Creations
Ask me a question!
You mean your compressor housing, back plate and blades are alot bigger than your old smaller type turbo. apart from that it is the same turbo
Old 18-06-2005, 09:31 AM
  #91
AustenW
AustenW's Avatar
8 injectors
jenvey inlet
all steel internals
Big valve head & cams
chargecooler that keeps a constant 35 degrees on full chat
MBE 970 (touring car ECU)
Quaife sequential gearbox
coil on plug
air to air boost control
anti lag
traction control
launch control
full throttle gearshift
AIM Mychron digital dash & datalogger
etc etc
carbon bodywork / titanium bits and bobs
circa 500kg
circa 400bhp for now (200 bhp is too much in these things, believe me)
= 800bhp per tonne
next is a GT turbo and tubular manifold for quick spool up but I'd like to get some use out of it this summer so I'm going to leave it as it is for now
Old 18-06-2005, 12:48 PM
  #92
chumkila
chumkila's Avatar
mental austin absolutely mental! LOL
Old 18-06-2005, 12:52 PM
  #93
Billabong
Billabong's Avatar
= 800bhp per tonne
Awesome!
(Jerry Springer mode on)Be careful out there (Jerry Springer mode off)
Old 18-06-2005, 12:56 PM
  #94
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
AustenW,
That IS the bollocks
Old 18-06-2005, 01:37 PM
  #95
sunny
sunny's Avatar
Should be awesome Austen!
Old 19-06-2005, 08:06 AM
  #97
Originally Posted by RANJ
lets lets the time`s do the talk
rest is speculation or ejaculation....
You car finished and put the times in ?
Hippykrit ?
Old 19-06-2005, 08:11 AM
  #98
Rod
Real tears
Old 19-06-2005, 09:34 PM
  #99
ze-vh phil
ze-vh phil's Avatar
dingy, i've got to admit i've got a real soft spot for mk2's and the more i look at your car, the more i realise i've got to own one and very soon
to sum it up, YOUR CARS THE SPUDS FELLA !!!!!!
Indyrs
04-12-2022 12:39 PM
07-10-2015 12:56 PM
Mikersturbo
27-09-2015 07:43 PM
IainRS1700T
25-09-2015 06:44 AM
Quick Reply: mental builds in progress?
