Twin fan on FRST?
Can it be done? Is the bonnet catch in the way? My baby is getting TOO hot and am trying everything posible to cool her down!
Also to be even cheekier, does any one have any pics of it been done?
Thanks
Vikki
Thanks
Vikki
![](https://passionford.com/forum/images/smilies/bisou.gif)
i want a fan as mine is broken. Anyway i would think you can do it, like RS Rawli said there is a identical space the otherside. But you could try a kenlow fan or aftermarket ones as they have differant size fans you can buy
Hope this helps
Hope this helps
you could disconect and remove the modine cooler that the oil filter sits on just have to re-direct the heater matrix pipe work by re-moving the y-splitter. it stops the oil from heating the water up once it's warm.
does take a little longer to warm up though. I was told to remove it by a engine builder so i haven't made it up.
i'm sure i read that fans block airflow above 30ish mph and with 2 fans on the front there's not much space left for air to get in. Or you could try a pace rad that really does help
Daniel
Daniel
Steve Escos
01-10-2015 06:57 AM
