SECS Monitor Wiring
Would have been nice if I was asked directly
MODULE CONNECTOR 1 PIN 8 (BLACK) > ECU PIN 1: GROUND
MODULE CONNECTOR 1 PIN 7 (RED) > ECU PIN 20: 12V POSITIVE SUPPLY
MODULE CONNECTOR 1 PIN 5 (GREY) > ECU PIN 25: IGNITION SIGNAL FOR RPM READING
MODULE CONNECTOR 1 PIN 4 (GREEN) > ECU PIN 17: THROTTLE POSITION SENSOR
MODULE CONNECTOR 1 PIN 3 (BLUE) > ECU PIN 29: ENGINE COOLANT TEMPERATURE SENSOR
MODULE CONNECTOR 1 PIN 2 (YELLOW) > ECU PIN 31: AIR CHARGE TEMPERATURE SENSOR
MODULE CONNECTOR 1 PIN 1 (WHITE) > ECU PIN 15: MAP SENSOR
Wire colours refere ro SECS loom NOT the ECU loom !!!
Mark RS
12-10-2015 06:01 AM
