rough idling and rich running
changed the headgasket on a 2wd cossie today due to a water leak. after putting it all back together it runs real rough.... doesnt idle properly and runs very rich. i have changed the act sender and there was a loose conection to the ect which has been done now but to no avail. ne ideas please
Check the Blue ECT sensor itself - easy to damage it or the wiring when removing/refitting the head. Also check MAP sensor pipes etc.
Any other symptoms, like smoke?
Lots of black smoke suggests either ECT or MAP sensors, had the same problem on mine a while back - was a bitch though, because they were both failing intermittent
ECT sensor is cheaper of the two, so perhaps change that first?
Mate, I had a Sapph' that had the same bodge (which obviously at the time I didn't realise) but it eventually failed again..... it's highly (imo) likely that's the issue, but as it's been 'repaired' before, I'd personally change it anyway.
Good luck.
Good luck.
