Injector flow testing/cleaning....
Old Jun 2, 2005 | 05:07 PM
ImaRacing 700's Avatar
ImaRacing 700
Default Injector flow testing/cleaning....
Is there much call for this as i have just been taught how to use out machine?
I would think it advisable to test even new injectors before risking a big build on the off chance you have a slightly dodgy injector!..Second hand ones a must..by cleaning them you got6 virtually a new set!!!
The machine tests for:-
Leaking
Flow rate
Spray pattern at various RPM loads
Precise cleaning
etc etc
Just tested a set of 1600cc injectors You wanna see these babies flow...LOL...no sign of any droplets either so should be ok for idle
Old Jun 2, 2005 | 05:20 PM
Billabong's Avatar
Billabong
Let me guess, they flowed 1600cc's?? (x4 )
Indeed Phil, some companies out there sell matched flow sets of new injectors - obviously time consuming, but worthwhile for a highly tuned engine.
I believe Stu has been able to offer injector flow testing/cleaning for some time.
Old Jun 2, 2005 | 05:23 PM
CosKev3's Avatar
CosKev3
Had mine done over the winter
£52 incl special delivery return post for set of four
http://www.injectorcleaning.co.uk/thanks.htm
24 hr turnaround too
Old Jun 2, 2005 | 05:29 PM
ImaRacing 700
Woo i be alot cheaper than that
Billy,Stu hasnt got the proper testing machine i dont beleive.
Old Jun 2, 2005 | 05:31 PM
Billabong's Avatar
Billabong
Unsure then Phil, as I thought Stu could have this done.
Do you have the facility to provide a printout, Phil?
Old Jun 2, 2005 | 05:34 PM
ImaRacing 700
Bill no but you get a hand written report lol...
Old Jun 2, 2005 | 05:37 PM
ImaRacing 700
The machine in that link above is the same one we have
Old Jun 2, 2005 | 05:45 PM
Billabong's Avatar
Billabong
Can you do RST injectors?
Old Jun 2, 2005 | 05:48 PM
ImaRacing 700
Old Jun 2, 2005 | 05:51 PM
Billabong's Avatar
Billabong
Old Jun 2, 2005 | 06:29 PM
RANJ's Avatar
RANJ
Default Re: Injector flow testing/cleaning....
Leaking
Flow rate
Precise cleaning
etc etc
Old Jun 2, 2005 | 07:30 PM
GUZZLER's Avatar
GUZZLER
i got a few sets of dark greens & had a perfecto set matched at Power Engineering for Sassy's 3 door. if you get a secondhand set or yours are a bit old its well worth doing.
mk3ste
Oct 17, 2021 10:09 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
fordrallycar
Sep 30, 2015 07:57 PM
