QUICK QUESTION....Bleed valves....
Old Jun 17, 2004 | 01:22 PM
keithG666's Avatar
keithG666
Default QUICK QUESTION....Bleed valves....
which way do you turn it to DECREASE boost????
Old Jun 17, 2004 | 01:23 PM
Jim Galbally's Avatar
Jim Galbally
clockwise...
right tight left loose
you want to tighten it basically
Old Jun 17, 2004 | 01:28 PM
james_birch's Avatar
james_birch
so is a bleed valve just adjustable boost then?
Old Jun 17, 2004 | 01:33 PM
keithG666's Avatar
keithG666
YES...but a bit hit and miss!!!
Old Jun 17, 2004 | 03:56 PM
plater's Avatar
plater
Safe enough to use if you have a boost gauge fitted to monitor exactly what level of boost your running. My 4x4 saf had a bleed valve fitted temporarily whilst i waited for a replacement amal valve. We set it to run 15 psi and ran like that without any problems, we did have a failsafe though, as my stage 1 chip cuts ignition power to the engine if the boost hits 17 psi.
tankybaby66
Feb 6, 2016 02:24 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
