Cosworth -31 actuator..
Re: Cosworth -31 actuator..
Originally Posted by SapphyMike
will a cossie -31 actuator work on an RS Turbo's turbocharger?
If it fits then it doesn't matter what turbo there is. I think.... Mine didn't wan't to fit so we made it fit! :-D
Originally Posted by Stu @ M Developments
If it fits, it works. Its just a spring.
The only problem woith fitting is getting correct lenghth rod. And when I got it the problem was to find enough strengh to put it on
Setting correct boost is a problem because the turbo is white hot and you really don't wanna touch it OR do you have some work around for that Stu?
if you need to streach the actuator rod over the wastegate thingio the easiest way to do it is use a foot pump and connect it to the actuator this will force the spring out and you can easily locate the rods hole over the wastegate mount
CheeRs
Phil
CheeRs
Phil
I just used force. I am so dumb at times. Will use compressor next time
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
Adam Graham
06-09-2015 06:04 AM
