help my mondie is broken
Hey all,
Have a mk1 mondeo 2.0 93, and have found that when the engine is running, it is burning through its coolant rapidily. No trace of water in the oil, and have noted steam emitting from the exhaust even when up to temp and on idle.
Also seems to hunt when idle, any help will be great..
Thanks in advance, Flooky.
*edited by Graceland - title words could be offensive*
Yep, agree, if you get someone to blip the throttle you'll see spatters of water on the floor too.
Hunting on Mondeos is common, normally either a wonkey plug in most cases or failing ISC valve.
Thanks, Thought it could of been the HG but wasn't sure as the oil seems to be ok, does smoke a lot but it has always smoked since I bypassed the UGR Valve as yes it's a common fault that makes the zetecs hunt!
Cheers for the replies guys n gurls. Flooky.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
155lee
24-10-2015 11:11 AM
07-10-2015 12:56 PM
