In DOS... Can u delete by creation date?
ditto what ebr said. i'm pretty sure the DEL command can only support filenames.
i do a similar thing here, but i use a VB program to do it for me
Hmmmm, using dos commands in NT, good luck!
Cant you just use the 'Find' command and specify a date for the file you want in a particular directory then highlight and delete them? You would then be able to retrieve them from the recycle bin if you made a mistake.
Ignor the above if you are writing a batch file though
What the other peeps said sounds good though
