technical brake question
Old May 23, 2005 | 11:14 AM
slowpoke's Avatar
slowpoke
Default technical brake question
bells and rotors, 310mm x 28 mm, when hot ie doing a track day how much would the rotors expect to expand by size wise ??
cheers.................matt
Old May 23, 2005 | 03:40 PM
slowpoke's Avatar
slowpoke
anyone at all ?????????????????
only 4 people even bothered to have a proper look
good old passionford eh
Old May 23, 2005 | 03:42 PM
Graceland's Avatar
Graceland
Team HOTHOT!
why get shitty about not getting a reply when not everyone has the technical data, the information about the material used, the LLoyds specification for the materials, and the heat range in which you are expecting expansion?
Old May 23, 2005 | 03:44 PM
Graceland's Avatar
Graceland
Team HOTHOT!
forgot to add
Old May 23, 2005 | 03:45 PM
foreigneRS's Avatar
foreigneRS
Testing the future
and in which direction? thickness, or diameter?
negligible amounts i would think. why do you need to know? clearance issues?
Old May 23, 2005 | 03:46 PM
slowpoke's Avatar
slowpoke
not gettin shitty about it paul just you ask a genuine question and only 4 people look at it !
whereas if i said top gear is on at 8 then i would of got 20 odd replys
not having a dig at anyone here by the way either
Old May 23, 2005 | 03:48 PM
slowpoke's Avatar
slowpoke
nick thanks for the reply
yes clearance issues with the ford calliper carrier that we had to modify, dont want to be goin round croft for the rotors to expand that much they fook the brakes up !
Old May 23, 2005 | 03:51 PM
Graceland's Avatar
Graceland
Team HOTHOT!
well, as i recall, all materials used have to be at a certain Lloyds specification and the heat buildup from braking should not have an affect if they are made properly using pukka materials - i'd say 0.1mm tops width and a negliable amount for diameter
Old May 23, 2005 | 03:59 PM
foreigneRS's Avatar
foreigneRS
Testing the future
what size rotors have you got on there? the expansion will obviously be a percentage of the starting size, but i can't imagine it being more than Graceland suggests. being in the rail industry, he probably knows a lot more about it than me.
Old May 23, 2005 | 04:09 PM
slowpoke's Avatar
slowpoke
they are made by hi spec tho pmsl god know what will happen lol
they are 310 mm x 28 mm rotors
i didnt expect it to be too much expansion but when i hareing round the track i want to know my brakes are going to work properly lol
cheers........matt
Old May 23, 2005 | 04:33 PM
Graceland's Avatar
Graceland
Team HOTHOT!
mate of mine, Dave, he has hispec 310mm roters and ally bells on his astra - not bad stoppers using the standard caliper, no problems as yet
Prickly_buzz
Dec 7, 2017 09:52 PM
155lee
Oct 27, 2015 04:55 AM
IainRS1700T
Sep 25, 2015 06:44 AM
The Enigma
Sep 12, 2015 10:12 PM
focus2351
Sep 9, 2015 09:33 PM
