Fly by Wire Throttle
Old May 18, 2005 | 09:44 PM
ian sibbert's Avatar
ian sibbert
Default Fly by Wire Throttle
Anyone seen this installed or has anyone installed it on a car?
Old May 18, 2005 | 09:47 PM
GARETH T's Avatar
GARETH T
give me two weeks,, and ill tell all,,, gotta check over a seat on motec in the next few weeks,,,
Old May 18, 2005 | 09:52 PM
ian sibbert
I knew you wouldn't let me down gareth
Something we have been looking at for a few weeks...just not had enough time to fully research so any input would be gratefully received...
Old May 18, 2005 | 09:55 PM
Danny B's Avatar
Danny B
vauxhall use this method now on astra's etc
Old May 18, 2005 | 09:56 PM
900ss's Avatar
900ss
RWD Racer
New clio, comes as std
GARETH T's Avatar
GARETH T
stu and simon might be worth a chat too
Old May 18, 2005 | 09:57 PM
GARETH T's Avatar
GARETH T
lots of cars use it,,, even my smart car
Old May 18, 2005 | 10:01 PM
900ss's Avatar
900ss
RWD Racer
What happens if you get a flat battery half way home
Be a slow drive home on tick over
Old May 18, 2005 | 10:02 PM
ian sibbert
We would just plug in the spare jump pack...no probs...believe me if the battery goes the throttle will be the least of my worries....
Old May 18, 2005 | 10:04 PM
GARETH T's Avatar
GARETH T
900ss, lots of other things start failing before a poxi servo drive
GARETH T's Avatar
GARETH T
im too slow tonight,,
Old May 18, 2005 | 10:06 PM
ian sibbert
I cant decide if i could do it stand alone...ive seen some on Vaux etc but I thought you ingenius lot might have some decent input....
Old May 18, 2005 | 10:08 PM
GARETH T's Avatar
GARETH T
im sure simon said in one of his posts that he has fitted a servo drive on a cossie throttle,,,
would be nice to have,,,,
Old May 18, 2005 | 10:12 PM
ECU Monitor Enthusiast
Needs to be integrated into a complete managment system to get any real benefits apart from the bling factor.
Mapped throttle position based on RPM/LOAD/THROTTLE DEMAND.
Main advantage is emmisions and can aid turbo spool up.
Ultimately , at wide open throttle. its like any other throttle !!!
Need multiple 3 dimensional maps to do it right - probally a bitch to set up and get right.
Have looked into doing this myself on my S8 ecu.
Just waiting for my mechanical wizard chap to sort out the oily bits then its
time to write some software.
Old May 18, 2005 | 10:18 PM
900ss's Avatar
900ss
RWD Racer
You’re right; my wife’s 12v powered dildo would be chucked away for starters
Old May 18, 2005 | 10:20 PM
Phil's Avatar
Phil
Jeebus
Am I correct in thinking that people using VAG 1.8 turbo engines remove this when getting to a certain power level? Food for thought anyway..
Old May 18, 2005 | 10:23 PM
ian sibbert
Simon,
That's the bit i was wondering about....we are looking at intergrating it first with a T6...which servo have you been looking at?
Old May 18, 2005 | 10:27 PM
GARETH T's Avatar
GARETH T
not on the one im looking at,,,
most people do it as its an easy way around the mapping,, and they dont need to buy an ecu which can do it
Old May 18, 2005 | 10:31 PM
ian sibbert
Wouldn't be to sure about it just being a bling thing....could be used to acheive all sorts of things....
Old May 18, 2005 | 10:34 PM
Sorry, very techie.....
I will be using a high power 6 phase direct drive stepper motor.
This will be controlled with high frequency PWM of about 5khz and phase shifted
voltage sequencing on the individual coils to provide a microstepping feature.
The result is a high torque drive with extreme accuracy.
Will also include a return spring so if the motor fails, it returns to fully shut position for safety.
The whole module will have its own on board microcontroller and linked to the ecu using a high speed CAN bus interface.
The original TPS ecu input will accept the new throttle pedal position sensor
Have yet to suss out how to do this.
Dont know how you would do this on a T6 or even know if its capable.
Best ask PECTEL directly.
Old May 18, 2005 | 10:35 PM
GARETH T's Avatar
GARETH T
i think simon thought you was on about building a stand along unit,,, not link too the ecu
so would only be a electronic throttle cable
the beifits for one controlled by the ecu is massive
Old May 18, 2005 | 10:38 PM
GARETH T, This system will be ECU integrated
Old May 18, 2005 | 10:40 PM
GARETH T's Avatar
GARETH T
SECS, i know yours would be mate
Old May 18, 2005 | 10:41 PM
You could make a standalone system but it would need some serious setting up development !!!
Old May 18, 2005 | 10:46 PM
ian sibbert
I BELIEVE the t6 is capable....i was really after a leg up with the hardware...i have a contact in M-SPORT who has helped us significantly with egr and gearcut mods I am just waiting for him to come back to me.....but some manf details etc to help with our development would have been of extreme use...
Ian
Old May 18, 2005 | 10:48 PM
ian sibbert
Apolgises Simon I might have thrown you off course....when I said standalone I always meant it to mean linked to the ecu...I believe some vehicles now have the system built into the ecu's.
The early system I have looked at used a serial link between the 'standalone' module and the ecu...
Old May 18, 2005 | 10:49 PM
sibster, Sounds good to me .... Good luck
Old May 18, 2005 | 10:57 PM
ian sibbert
Thanks simon...i'll take that as a no then !!
Ian
Old May 19, 2005 | 01:03 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
some great ideas and concepts that can and will in time be used.
Old May 19, 2005 | 07:58 AM
AlexF's Avatar
AlexF
hmmm and if it fails open?
Be careful on this development lads... think over-ride buttons... or emergency engine cut!
400bhp vs your brakes is not a fair contest!
Alex
Old May 19, 2005 | 10:19 AM
Jahman's Avatar
Jahman
My BMW has that and i hate it Not responsive at all...
Old May 19, 2005 | 07:17 PM
GARETH T's Avatar
GARETH T
theres always a clutch pedal
Old May 19, 2005 | 07:37 PM
seveneigths's Avatar
seveneigths
Sibster, did you get a WRC 8 injector manifold for your car.
Paul
Old May 19, 2005 | 08:04 PM
richm's Avatar
richm
i had a saab Carlsson with FBW throttle, it was an arse.. dunno what the advantages were meant to be, but i didn't find any on that thing
It was integrated with traction control too, which lifted the throttle.. that was even worse, and you couldn't turn any of it off!!
Old May 19, 2005 | 09:13 PM
It's Czech Mate's Avatar
It's Czech Mate
ST150
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
