Quick DV question
Old May 18, 2005 | 07:27 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default Quick DV question
Would removing the hose from inlet manifold to DV effectively disable the DV, or, would it mean it would leak boost pressure like a sieve ?
PS: D/V vents to atmosphere, not re-circulating if it makes a difference.
Thanks in advance
Greg
Old May 18, 2005 | 07:35 AM
Stu @ M Developments's Avatar
PassionFords Creator
It will leak if the boost pressure exceeds the spring pressure.
Old May 18, 2005 | 08:08 AM
frog's Avatar
frog
Oh bugger
Thanks Stu
Old May 18, 2005 | 09:43 AM
EssexBoyRacer's Avatar
EssexBoyRacer
thinking about making it turn on and off?
Old May 18, 2005 | 10:09 AM
frog's Avatar
frog
Note quite, MrsFrog wants hers off, but I don't have a blanking plug, and don't really want to put a piece of broom handle in there... So I thought I'd just be able to disconnect the pipe to it
I'd like to be able to turn mine on/off though, nice to have it on when you're on a leisurely (sp?) drive and can't be arsed with all the noise (std ford recirc. one), and turn it off when you want a bit of chatter to brighten up the day...
Oh well... or, is there a solution to this
Old May 18, 2005 | 10:24 AM
EssexBoyRacer
yup! u can use an amal valve in the vacume pipe to control the dump valve. Gives u the ability to turn it on and off from the flick of a switch inside the car.
But as per stu, when on big boost the dump valve might leak so u'd probably need to have it switched on when u're giving it beans (but u could get round this with a pressure switch if u wanted to be really flash!)
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
