Digital Speedos
Digital Speedos
Thinkin g of ditching the speedo on the car and fitting something else... What digital options are there?
and whats the legality of it all? do you have to keep an odometer on the car etc?
just finding my feet
where you guys meeting up , im gonna go to scots and take the ibiza for maybe the kast journey there
as i cant be arsed to get the batt oout the cossie
Day off mate. All I've managed to do all day is pop out and grab the Gumball DVD and watch it. Sposed to have tidied the spare room and done a couple jobs on the car but just couldn't be arsed.
does it also talk to you and do ya get a watch to stay in comunication
does ya cossie have a red LED on the front of it Mich,,,,,,,,, sorry Stretch
and even worse if jim buys it then ya never gonna sell another one
6 individual circuit boards allow installation flexibility for custom panels.
Full LED lighting.
0-100 PSI oil pressure gauge and sender reads in 1lb. increments for precise readings.
50-350 degree water temperature gauge and sender.
8-18 volt voltmeter with low and high volts warning.
0-99% fuel level gauge.
300 mph digital speedometer with LED bar graph, odometer with trop.
Recalls highest speed, 1/4 mile ET and 0-60 time.
Easy one button calibration for various axle ratios & tire sizes.
Can be used with most existing electronic speed senders or use the included S9013 for cable driven applications.
0-9900 rpm digital tachometer in 100-rpm increments with LED bar graph.
Left and right turn signal indicators.
High beam indicator.
Microprocessor controlled for accuracy and dependability.
Blacks out completely when powered off.
Available in High Brightness Red, Green, Amber or Blue.
Lifetime warranty.
Full LED lighting.
Lifetime warranty.
You need to wire it into car.Which isnt that bad if you know anything about electics.
Fitting is easy enough or i can supply it ready to go in A sapphire clock surround but would still require wiring sorting out.
www.ctuceilings.co.uk
Seeing as we are posting pictures of digital dashes. I better do mine before Damo does lol
A street car HAS to have a working mile counter... Whatever it is called
sketch, what do you do about the speed sensor then? can somehting be fitted to the fton wheels?
also what about the ABS light? altho TBH its gonna need a hooky mot testerto pass anyway
My name is STRETCH NOT Sketch
The speed sensor plugs into existing cable And is as accurate as my snooper s4 and road angel i have had in car.
You can always wire up an ABS light off existing wiring as i will be doing once i find a new dashboard.Complete with new light for battery and oil light.
i assume the revcounter is configurable so i cn run it on a 6cyl? and does it cme with its own sub-loom or do i have to remake all the wiring to the back of the unit?
does it have any warning light functions?
is there a website or something i can look at?
Rev counter will work with 4 6 and 8 cylinder cars.
I used original wiring and a few new ones.Easy enough if you know electrics.
Only warning lights are indicators and main beam.Battery flashes if either low or high.
salsheikh
Alloy wheels and ICE for sale
30-07-2015 08:45 PM
